Old April 16th, 2011, 14:48   #31
Daniel
Daniel's Avatar
624 Total
Originally Posted by winniethebeer View Post
well if it makes you feel better, you win on the category "links with no carries but porno sites that try to install spyware on my pc"
For all but not for me.
Daniel is offline
Old April 16th, 2011, 16:30   #32
greybeezer
greybeezer's Avatar
1,480 Total
Originally Posted by Daniel View Post
Maybe you even say that I have access to the VIP area is also on the lottery? Do not believe it.
There is no lottery for VIP, and I once asked the other admins if it was ok to promote you to VIP again they all voted against you. After which you turned around and slanderd me in this forum and others, and don't think for a minute that I didn't see the thread you started in a Russian forum title F**& OFF greybeezer. I am trying to be nice with you lately so stop testing my paitence, if you are in the top 10 thanks getters and your name is randomly drawn by a computer program not an admin then you will get a free clip.
greybeezer is offline
Old May 1st, 2011, 08:06   #33
5,455 Total
April 2011:
The 5 highest F/F post ratings in April 2011:
  1. Got 24 "thank you" clicks: #55534 (ganju90)
  2. Got 20 "thank you" clicks: #55762 (ganju90)
  3. Got 17 "thank you" clicks: #56113 (ganju90)
  4. Got 15 "thank you" clicks: #55918 (ganju90)
  5. Got 13 "thank you" clicks: #55354 (tragmich), #55740 (blauesau), #56103 (ganju90)
The 5 highest F/F post ratings since the post ratings started:
  1. Got 26 "thank you" clicks: #47695 (ganju90)
  2. Got 24 "thank you" clicks: #55534 (ganju90)
  3. Got 20 "thank you" clicks: #55762 (ganju90)
  4. Got 19 "thank you" clicks: #50039 (Leobor)
  5. Got 18 "thank you" clicks: #51855 (justpassingthru88)
The 5 highest F/M post ratings in April 2011:
  1. Got 36 "thank you" clicks: #55634 (ganju90)
  2. Got 35 "thank you" clicks: #55429 (ganju90)
  3. Got 22 "thank you" clicks: #55760 (ganju90)
  4. Got 19 "thank you" clicks: #54713 (dendrin)
  5. Got 16 "thank you" clicks: #56044 (ganju90)
The 5 highest F/M post ratings since the post ratings started:
  1. Got 60 "thank you" clicks: #47984 (ocatcher)
  2. Got 44 "thank you" clicks: #47697 (ganju90)
  3. Got 36 "thank you" clicks: #55634 (ganju90)
  4. Got 35 "thank you" clicks: #43994 (filmguy), #55429 (ganju90)
  5. Got 32 "thank you" clicks: #49894 (gsr3032000)
The 10 highest number of thanks received by a single (non-admin) member in April 2011:
  1. Got 293 "thank you" clicks: ganju90
  2. Got 86 "thank you" clicks: wm1122
  3. Got 70 "thank you" clicks: blauesau, pqowieus2000
  4. Got 63 "thank you" clicks: X-MiND
  5. Got 43 "thank you" clicks: SDS
  6. Got 37 "thank you" clicks: xtc
  7. Got 26 "thank you" clicks: bsn0327
  8. Got 23 "thank you" clicks: kangquasar
  9. Got 20 "thank you" clicks: geniuslb, poldo1965
  10. Got 19 "thank you" clicks: lionman
The 10 highest number of thanks received by a single (non-admin) member since the post ratings started:
  1. Got 565 "thank you" clicks: pqowieus2000
  2. Got 526 "thank you" clicks: wm1122
  3. Got 508 "thank you" clicks: kangquasar
  4. Got 472 "thank you" clicks: ganju90
  5. Got 250 "thank you" clicks: blauesau
  6. Got 226 "thank you" clicks: ocatcher
  7. Got 164 "thank you" clicks: Bacha, SDS
  8. Got 161 "thank you" clicks: lenny
  9. Got 137 "thank you" clicks: gsr3032000
  10. Got 134 "thank you" clicks: geniuslb
This month's clip winners will be announced tomorrow.
X-MiND (May 4th, 2011)
Old May 1st, 2011, 09:53   #34
goneju
Guest
Posts: n/a
Originally Posted by dp View Post
April 2011:
There is some serious mistake happened in counting the number of thanks. My total number of Thanks are more than 740 and they were 177 in March end so Total number is more than 550 this month alone. Same thing applies for my individual posts as for example this particular post http://landcforum.com/forums/showthr...p?t=707&page=4 has got 34 Thanks but it is not showing above. Same way there are other posts in this month which are not reflected above.
Old May 1st, 2011, 11:35   #35
5,455 Total
Good catch ganju, it seems that the "thanks" plugin to the forum has some broken data in the database that could not be used when making the summaries. Updated scores will follow - please check it and see if it looks good now.
Old May 1st, 2011, 11:40   #36
5,455 Total
April 2011 (corrected numbers):
  1. Got 34 "thank you" clicks: #56223 (ganju90)
  2. Got 26 "thank you" clicks: #56417 (ganju90)
  3. Got 24 "thank you" clicks: #55534 (ganju90)
  4. Got 22 "thank you" clicks: #55762 (ganju90), #56113 (ganju90)
  5. Got 21 "thank you" clicks: #56103 (ganju90)
  2. Got 26 "thank you" clicks: #47695 (ganju90), #56417 (ganju90)
  3. Got 28 "thank you" clicks: #56222 (ganju90)
  4. Got 23 "thank you" clicks: #55760 (ganju90)
  5. Got 20 "thank you" clicks: #54713 (dendrin)
  1. Got 556 "thank you" clicks: ganju90
  2. Got 125 "thank you" clicks: wm1122
  3. Got 76 "thank you" clicks: blauesau
  4. Got 73 "thank you" clicks: pqowieus2000
  5. Got 66 "thank you" clicks: X-MiND
  6. Got 46 "thank you" clicks: SDS, xtc
  7. Got 45 "thank you" clicks: bsn0327
  9. Got 22 "thank you" clicks: chewwah2007, geniuslb
  10. Got 21 "thank you" clicks: lionman, mate
  1. Got 735 "thank you" clicks: ganju90
  2. Got 568 "thank you" clicks: pqowieus2000
  3. Got 565 "thank you" clicks: wm1122
  4. Got 509 "thank you" clicks: kangquasar
  5. Got 256 "thank you" clicks: blauesau
  7. Got 167 "thank you" clicks: SDS
  8. Got 164 "thank you" clicks: Bacha
  9. Got 161 "thank you" clicks: lenny
  10. Got 138 "thank you" clicks: gsr3032000
X-MiND (May 4th, 2011), (May 1st, 2011)
Old May 1st, 2011, 13:02   #37
goneju
Guest
Posts: n/a
It looks one way traffic. My name flashing in almost all Top 10 List this month. 556 Thanks in a month. Thats some effort and I never expected it to be so high. But its record that will remain forever on this forum. Maybe I will try to break it in coming months. It needs some serious serious contribution from someone to break it. I would love to see this record being broken by someone in near future.
Old May 2nd, 2011, 15:29   #38
Nateliftee
The "2nd" first member
Nateliftee's Avatar
56 Total
Did it again. Put "thanks" (removed) instead of "quote". You don't mind do you Ganju? What I really wanted to say was Katsou has been missing for a while. I wonder if he is racking up new cam clips for all of us to see. Then he might break your thanks record.
Biggest Mouth On The Board-er
Nateliftee is offline
Old May 2nd, 2011, 16:30   #39
goneju
Guest
Posts: n/a
I will be really happy if he or anyone does so.
Old May 3rd, 2011, 02:12   #40
justpassingthru88
1,315 Total
I do good to find the TIME to find material, much less find material.
You're just the awesome.
justpassingthru88 is online now
