June 21st, 2011, 23:35 | #561 | |
0 For This Post 446 Total |
Also, do you think there's any possibility you might switch to a higher resolution camera at any point? I understand if it's not possible - I know they're expensive/hard to get. |
June 22nd, 2011, 00:03 | #562 | |
0 For This Post 205 Total |
Unfortunately, at this point in time switching to a higher res camera isn't practical for me. The camera that I currently have is only about a year and a half old, and the raw file sizes are almost as large as true high def cameras. Where I lose some of the quality is more on the back end in the editing software that I am currently using. It is very bsic, but easy to use, and works well or me. I will try playing with the lighting and the editing in the future and see what I can do.
Hugs & Kisses, Rachel www.clips4sale.com/39486 |
June 23rd, 2011, 22:46 | #563 |
2 For This Post 205 Total |
Rachel's Lift and Carry Seduction
This is Rachel's most sensual lift and carry video yet!
Rachel is in a playful and mischievous mood and decides Rick is the perfect playtoy. She tells him she wants to try a new lift and has him lay on top of her. She then proceeds to perform pelvic thrust lifts with the 220 pound man! Rachel then performs between the leg lifts with both legs and single legs, cradles, over the shoulder, fireman's carry, and several more lifts while teasing him all throughout. Now that Rachel is all warmed up and turned on, she puts on a pair of 6" platform heels and pins Rick up against the wall and dances for him. She then strips him down to his underwear, takes off her top and puts him on her back for some lifting and deep kissing, She performs several lifts including cradles, front straddles, piggybacks and lap sitting while passionately kissing Rick. Rachel shows she is in complete control by picking Rick up in a front straddle with her platform heels on, putting him against the wall and pins both of his hand behind his head while deep kissing him. If Rachel can do this to a 6'2" 220 lbs man, think of what she can do to you! http://www.clips4sale.com/39486
June 26th, 2011, 09:21 | #564 |
0 For This Post 127 Total |
tiny petite girl
Hi lovely Rachel,
what about the lifting clips with a tiny petite 90lbs-Girl? I am still waiting. Did you find a girl and a common date? Minimax |
July 1st, 2011, 21:47 | #565 | |
I haven't found one quite that small yet but I am releasing another petite girl getting lifted shortly. It will be my next clip.
July 1st, 2011, 22:48 | #566 |
Light as a Feather
Kaycee is in her best shape yet. At 5'11", this sexy blonde is toned, statuesque, and looking to put her amazon strength to the test. The sexy raven haired Choice is the perfect liftee. At 5' 3", the petite and slimmed down Choice looks as beautiful as ever in her hot pink bikini.
Kaycee wastes no time lifting and tossing Choice around as she is as light as a feather in her arms. Kaycee performs bicep curls with Choice in a cradle position, fireman's carries, over the shoulders, side and front straddles, back to back, ponyrides, airplane rides, squats and calf raises, one arm crotch lifts and much more. Kaycee also efffortlessly peforms a flawless gorilla overhead press with Choice and holds her in this position as she walks around the room with her high overhead! If you are a fan of seeing a strong amazon woman lift a much smaller petite one, then you will love this video! http://www.clips4sale.com/39486
July 4th, 2011, 17:55 | #567 | |
0 For This Post 57 Total |
Nice job. |
July 4th, 2011, 18:16 | #568 | |
1 For This Post 205 Total |
I try to use and find a variety of different girls, both in shape, size and ethnicity to keep things interesting. I know everyone has different tastes so I want to make sure I have something for everyone!
July 4th, 2011, 18:33 | #569 |
0 For This Post 10,998 Total |
The one armed crotch lift by Kaycee is an impressive lift. You could try it as well or even a two arm version from directly behind them or in front of them.
July 4th, 2011, 22:23 | #570 | |
That was actually an impromptu lift by Kaycee but I will try to incorporate both the one arm and two arm versions into future videos
