Old February 1st, 2012, 13:05   #71
goneju
Guest
Posts: n/a
Originally Posted by dp View Post
January 2012:
The top 10 F/F posts in January 2012:
  1. Got 36 "thank you" clicks: #75014 (mishamironovv)
  2. Got 35 "thank you" clicks: #76416 (ponyplay)
  3. Got 30 "thank you" clicks: #76520 (dendrin)
  4. Got 25 "thank you" clicks: #74699 (thracian), #74899 (SDS)
  5. Got 24 "thank you" clicks: #76761 (mankan77)
  6. Got 23 "thank you" clicks: #75579 (perun ffcarries), #76846 (wm1122)
  7. Got 21 "thank you" clicks: #76225 (blauesau)
  8. Got 18 "thank you" clicks: #75265 (blauesau), #75771 (ponyplay), #75798 (perun ffcarries)
  9. Got 16 "thank you" clicks: #76878 (ganju90)
  10. Got 15 "thank you" clicks: #75724 (blauesau), #77134 (cmcwmod)
The top 10 F/F posts since the post ratings started:
  1. Got 37 "thank you" clicks: #56223 (ganju90)
  2. Got 36 "thank you" clicks: #56417 (ganju90), #68214 (explore9999), #75014 (mishamironovv)
  3. Got 35 "thank you" clicks: #76416 (ponyplay)
  4. Got 33 "thank you" clicks: #64265 (dendrin), #73169 (dendrin)
  5. Got 32 "thank you" clicks: #61136 (wm1122)
  6. Got 30 "thank you" clicks: #68422 (explore9999), #76520 (dendrin)
  7. Got 27 "thank you" clicks: #58787 (ganju90), #59918 (lunchbox682)
  8. Got 26 "thank you" clicks: #47695 (ganju90), #55534 (ganju90)
  9. Got 25 "thank you" clicks: #56113 (ganju90), #56914 (ganju90), #59294 (ganju90), #60677 (delura), #74699 (thracian), #74899 (SDS)
  10. Got 24 "thank you" clicks: #69307 (geniuslb), #73235 (blauesau), #74582 (perun ffcarries), #76761 (mankan77)
The top 10 F/M posts in January 2012:
  1. Got 20 "thank you" clicks: #76320 (kangquasar), #77170 (gsr3032000)
  2. Got 17 "thank you" clicks: #77167 (gsr3032000)
  3. Got 16 "thank you" clicks: #75896 (dendrin)
  4. Got 15 "thank you" clicks: #74818 (mpaneole)
  5. Got 13 "thank you" clicks: #75552 (ganju90), #77173 (gsr3032000)
  6. Got 12 "thank you" clicks: #77024 (felix)
  7. Got 11 "thank you" clicks: #75321 (tragmich), #75529 (chewwah2007), #75558 (butik000), #77048 (phoneman), #77204 (shuklarr)
  8. Got 10 "thank you" clicks: #75101 (Kryten), #75576 (wilk1978), #76220 (ganju90), #76350 (fcfcao), #77169 (gsr3032000), #77175 (gsr3032000)
  9. Got 9 "thank you" clicks: #74862 (ganju90), #75179 (blauesau), #75907 (dsf524), #75935 (xvall), #76476 (anaso), #76647 (ganju90), #76760 (dimasna)
  10. Got 8 "thank you" clicks: #74717 (ericfabre), #74757 (kumar3210), #75927 (MistressTaylor), #76518 (blauesau)
The top 10 F/M posts since the post ratings started:
  1. Got 62 "thank you" clicks: #47984 (ocatcher)
  2. Got 51 "thank you" clicks: #71164 (enrycento)
  3. Got 46 "thank you" clicks: #47697 (ganju90)
  4. Got 43 "thank you" clicks: #73881 (Bacha)
  5. Got 38 "thank you" clicks: #55634 (ganju90)
  6. Got 37 "thank you" clicks: #74514 (gsr3032000)
  7. Got 36 "thank you" clicks: #55429 (ganju90)
  8. Got 35 "thank you" clicks: #43994 (filmguy), #58616 (ganju90)
  9. Got 34 "thank you" clicks: #57127 (phoneman), #73490 (wm1122)
  10. Got 32 "thank you" clicks: #49894 (gsr3032000), #66445 (eagle_one)
The 10 highest number of thanks received by a single (non-admin) member in January 2012:
  1. Got 233 "thank you" clicks: blauesau
  2. Got 149 "thank you" clicks: ganju90
  3. Got 114 "thank you" clicks: mankan77
  4. Got 100 "thank you" clicks: kangquasar
  5. Got 97 "thank you" clicks: gsr3032000
  6. Got 96 "thank you" clicks: crazy_ots
  7. Got 66 "thank you" clicks: Bazzese
  8. Got 61 "thank you" clicks: ericfabre
  9. Got 50 "thank you" clicks: jvzann
  10. Got 45 "thank you" clicks: egefaloz
The 10 highest number of thanks received by a single (non-admin) member since the post ratings started:
  1. Got 2166 "thank you" clicks: ganju90
  2. Got 1515 "thank you" clicks: kangquasar
  3. Got 1434 "thank you" clicks: blauesau
  4. Got 1343 "thank you" clicks: wm1122
  5. Got 1112 "thank you" clicks: geniuslb
  6. Got 666 "thank you" clicks: pqowieus2000
  7. Got 644 "thank you" clicks: gsr3032000
  8. Got 478 "thank you" clicks: lionman
  9. Got 436 "thank you" clicks: xtc
  10. Got 431 "thank you" clicks: Bacha
There seems to be some mistake. Last month my total Thanks were 1955. This month its 2166. The difference is 211. But instead its showing 149 this month.
Old February 1st, 2012, 15:03   #72
blauesau
blauesau's Avatar
8,755 Total
Is it possible to post this list with all people, admins inclusive? Thanks...
blauesau is offline
Old February 1st, 2012, 15:21   #73
5,455 Total
There's no mistake. The difference (211-149 = 62) is thanks that was given for older posts (i.e., posts made before January 2012). You can still get thanks for those, years after you made the posts (from new members for example), but they only count towards your all-time total, not the monthly sums.
Old February 1st, 2012, 15:26   #74
5,455 Total
It is possible, but we excluded admins because they would occupy too many positions in the top 10 lists. We did this to make it easier for regular members to show up in the top 10 lists. Here are last month's lists with admins included:
The 10 highest number of thanks received by a single member in January 2012:
  3. Got 139 "thank you" clicks: perun ffcarries
  4. Got 114 "thank you" clicks: mankan77
  5. Got 100 "thank you" clicks: kangquasar
  6. Got 97 "thank you" clicks: gsr3032000
  7. Got 96 "thank you" clicks: crazy_ots
  8. Got 75 "thank you" clicks: dendrin
  9. Got 73 "thank you" clicks: tragmich
  10. Got 70 "thank you" clicks: lifted
The 10 highest number of thanks received by a single member since the post ratings started:
  2. Got 1767 "thank you" clicks: tragmich
  3. Got 1585 "thank you" clicks: perun ffcarries
  4. Got 1515 "thank you" clicks: kangquasar
  5. Got 1434 "thank you" clicks: blauesau
  6. Got 1343 "thank you" clicks: wm1122
  7. Got 1112 "thank you" clicks: geniuslb
  8. Got 990 "thank you" clicks: dendrin
  9. Got 892 "thank you" clicks: phoneman
  10. Got 666 "thank you" clicks: pqowieus2000
blauesau (February 1st, 2012)
Old March 6th, 2012, 15:05   #75
5,455 Total
February 2012:
The top 10 F/F posts in February 2012:
  1. Got 28 "thank you" clicks: #78584 (wm1122)
  2. Got 23 "thank you" clicks: #79019 (dendrin), #79051 (gsr3032000), #79059 (gsr3032000), #79357 (JSimoni)
  3. Got 22 "thank you" clicks: #78876 (blauesau)
  4. Got 21 "thank you" clicks: #79054 (gsr3032000), #79058 (gsr3032000)
  5. Got 18 "thank you" clicks: #77485 (mankan77), #78736 (alphafemale), #79052 (gsr3032000)
  6. Got 15 "thank you" clicks: #78284 (ramonra), #79049 (gsr3032000), #79050 (gsr3032000)
  7. Got 14 "thank you" clicks: #78826 (JSimoni), #79057 (gsr3032000)
  8. Got 13 "thank you" clicks: #77875 (chewwah2007), #77928 (perun ffcarries), #78102 (perun ffcarries), #78773 (kangquasar), #78950 (ericfabre), #79396 (sheppy)
  9. Got 12 "thank you" clicks: #77383 (ericfabre), #78171 (pirrikio), #78231 (enrycento), #78748 (wilk1978), #78984 (Temeraire), #79037 (eva40138), #79150 (marplity)
  10. Got 11 "thank you" clicks: #77421 (perun ffcarries), #77531 (ericfabre), #77594 (dendrin), #77737 (mankan77), #77921 (tragmich), #78504 (blauesau), #78679 (perun ffcarries), #78912 (blauesau), #79661 (perun ffcarries)
  4. Got 34 "thank you" clicks: #73169 (dendrin)
  5. Got 33 "thank you" clicks: #64265 (dendrin)
  6. Got 32 "thank you" clicks: #61136 (wm1122)
  7. Got 30 "thank you" clicks: #68422 (explore9999), #76520 (dendrin)
  8. Got 28 "thank you" clicks: #78584 (wm1122)
  9. Got 27 "thank you" clicks: #58787 (ganju90), #59918 (lunchbox682)
  10. Got 26 "thank you" clicks: #47695 (ganju90), #55534 (ganju90)
The top 10 F/M posts in February 2012:
  1. Got 39 "thank you" clicks: #78361 (goldendoggy)
  2. Got 34 "thank you" clicks: #78586 (wm1122)
  3. Got 27 "thank you" clicks: #77652 (Bacha)
  4. Got 22 "thank you" clicks: #78775 (kangquasar), #79519 (gsr3032000)
  5. Got 20 "thank you" clicks: #77823 (tragmich), #79518 (gsr3032000)
  6. Got 19 "thank you" clicks: #77536 (ganju90)
  7. Got 17 "thank you" clicks: #77469 (poldo1965), #79716 (sam_neil)
  8. Got 16 "thank you" clicks: #79043 (aedgar)
  9. Got 15 "thank you" clicks: #78284 (ramonra)
  10. Got 14 "thank you" clicks: #78446 (blauesau), #78797 (xirgu20)
  5. Got 39 "thank you" clicks: #78361 (goldendoggy)
  6. Got 38 "thank you" clicks: #55634 (ganju90)
  7. Got 37 "thank you" clicks: #74514 (gsr3032000)
  8. Got 36 "thank you" clicks: #55429 (ganju90)
  9. Got 35 "thank you" clicks: #43994 (filmguy), #58616 (ganju90)
  10. Got 34 "thank you" clicks: #57127 (phoneman), #73490 (wm1122), #78586 (wm1122)
The 10 highest number of thanks received by a single (non-admin) member in February 2012:
  1. Got 192 "thank you" clicks: gsr3032000
  2. Got 179 "thank you" clicks: blauesau
  3. Got 101 "thank you" clicks: ganju90
  4. Got 83 "thank you" clicks: ericfabre
  5. Got 81 "thank you" clicks: wm1122
  6. Got 78 "thank you" clicks: kangquasar
  7. Got 73 "thank you" clicks: goldendoggy
  8. Got 71 "thank you" clicks: mankan77
  9. Got 57 "thank you" clicks: millmiller
  10. Got 43 "thank you" clicks: poldo1965
  1. Got 2293 "thank you" clicks: ganju90
  2. Got 1650 "thank you" clicks: blauesau
  3. Got 1600 "thank you" clicks: kangquasar
  4. Got 1426 "thank you" clicks: wm1122
  5. Got 1116 "thank you" clicks: geniuslb
  6. Got 870 "thank you" clicks: gsr3032000
  7. Got 707 "thank you" clicks: pqowieus2000
  8. Got 501 "thank you" clicks: lionman
  9. Got 478 "thank you" clicks: Bacha
  10. Got 440 "thank you" clicks: poldo1965, xtc
Old April 26th, 2012, 23:38   #76
5,455 Total
March 2012:
The top 10 F/F posts in March 2012:
  1. Got 27 "thank you" clicks: #81633 (mishamironovv)
  2. Got 23 "thank you" clicks: #79760 (wm1122)
  3. Got 22 "thank you" clicks: #81197 (wm1122)
  4. Got 21 "thank you" clicks: #80452 (gsr3032000)
  5. Got 20 "thank you" clicks: #80167 (wm1122), #80857 (dendrin), #81055 (Simba007), #81267 (perun ffcarries), #81930 (ericfabre)
  6. Got 18 "thank you" clicks: #80943 (wm1122), #81497 (blauesau)
  7. Got 17 "thank you" clicks: #79802 (ganju90), #80609 (blauesau), #80759 (sam_neil), #81907 (ffcarry3746)
  8. Got 16 "thank you" clicks: #80662 (loyd_carr), #81050 (mankan77), #81283 (ganju90), #81818 (Pickboy100)
  9. Got 15 "thank you" clicks: #80346 (gsr3032000), #80443 (gsr3032000), #80678 (forevernate28), #81140 (SDS)
  10. Got 14 "thank you" clicks: #79829 (alexisrain), #80212 (blauesau), #80442 (gsr3032000), #80543 (dendrin)
  1. Got 37 "thank you" clicks: #56223 (ganju90), #68214 (explore9999), #75014 (mishamironovv)
  4. Got 34 "thank you" clicks: #64265 (dendrin), #73169 (dendrin)
  6. Got 31 "thank you" clicks: #76520 (dendrin)
  9. Got 27 "thank you" clicks: #58787 (ganju90), #59918 (lunchbox682), #81633 (mishamironovv)
The top 10 F/M posts in March 2012:
  1. Got 44 "thank you" clicks: #81057 (Mike)
  2. Got 23 "thank you" clicks: #79925 (kangquasar)
  3. Got 19 "thank you" clicks: #79729 (macedonia), #81178 (WarandWin)
  4. Got 18 "thank you" clicks: #80287 (load), #80366 (ganju90), #80457 (blauesau)
  5. Got 16 "thank you" clicks: #81013 (ganju90)
  6. Got 15 "thank you" clicks: #79918 (Brandfuchs)
  7. Got 14 "thank you" clicks: #79829 (alexisrain), #80201 (roche), #80347 (aedgar), #80665 (loyd_carr), #80747 (poldo1965)
  8. Got 13 "thank you" clicks: #80892 (rickishi), #81096 (bader)
  9. Got 12 "thank you" clicks: #79869 (ganju90), #81914 (kangquasar)
  10. Got 11 "thank you" clicks: #80826 (kangquasar), #81315 (FinQ)
  4. Got 44 "thank you" clicks: #81057 (Mike)
  5. Got 43 "thank you" clicks: #73881 (Bacha)
  6. Got 39 "thank you" clicks: #78361 (goldendoggy)
  7. Got 38 "thank you" clicks: #55634 (ganju90)
  8. Got 37 "thank you" clicks: #74514 (gsr3032000)
  9. Got 36 "thank you" clicks: #55429 (ganju90)
  10. Got 35 "thank you" clicks: #43994 (filmguy), #58616 (ganju90), #78586 (wm1122)
The 10 highest number of thanks received by a single (non-admin) member in March 2012:
  1. Got 259 "thank you" clicks: blauesau
  2. Got 183 "thank you" clicks: ganju90
  3. Got 161 "thank you" clicks: kangquasar
  4. Got 121 "thank you" clicks: gsr3032000
  5. Got 111 "thank you" clicks: ericfabre
  6. Got 92 "thank you" clicks: wm1122
  7. Got 80 "thank you" clicks: SDS
  8. Got 63 "thank you" clicks: ffcarry3746
  9. Got 60 "thank you" clicks: poldo1965
  10. Got 56 "thank you" clicks: millmiller
  1. Got 2485 "thank you" clicks: ganju90
  2. Got 1935 "thank you" clicks: blauesau
  3. Got 1764 "thank you" clicks: kangquasar
  4. Got 1520 "thank you" clicks: wm1122
  5. Got 1129 "thank you" clicks: geniuslb
  6. Got 1000 "thank you" clicks: gsr3032000
  8. Got 533 "thank you" clicks: lionman
  9. Got 502 "thank you" clicks: poldo1965
  10. Got 498 "thank you" clicks: ericfabre
Old May 3rd, 2012, 12:30   #77
5,455 Total
Here are April's numbers. Also note that the numbers for March has been updated, because an error happened when calculating last months numbers (many posts were excluded because an incorrect forum database was used).
April 2012:
The top 10 F/F posts in April 2012:
  1. Got 24 "thank you" clicks: #82902 (ericfabre)
  2. Got 22 "thank you" clicks: #82145 (wm1122)
  3. Got 21 "thank you" clicks: #82194 (blauesau), #82226 (wm1122), #82933 (blauesau)
  4. Got 19 "thank you" clicks: #83349 (ffcarry3746)
  5. Got 18 "thank you" clicks: #82961 (blauesau), #83082 (wm1122), #83166 (tragmich)
  6. Got 17 "thank you" clicks: #82160 (ganju90), #83093 (ffcarry3746), #83418 (ffcarry3746), #83466 (tragmich), #83772 (perun ffcarries)
  7. Got 16 "thank you" clicks: #82046 (ffcarry3746), #82357 (ffcarry3746), #82444 (SDS)
  8. Got 15 "thank you" clicks: #82980 (dendrin), #83299 (ericfabre), #83851 (ericfabre)
  9. Got 14 "thank you" clicks: #82595 (sam_neil), #82639 (tragmich), #82845 (kangquasar), #83083 (wm1122)
  10. Got 13 "thank you" clicks: #82400 (ganju90), #82620 (ffcarry3746), #82840 (perun ffcarries), #83690 (Borborygmus), #83925 (wm1122)
The top 10 F/M posts in April 2012:
  1. Got 30 "thank you" clicks: #82227 (wm1122)
  2. Got 27 "thank you" clicks: #82047 (blauesau)
  3. Got 19 "thank you" clicks: #82212 (ricky1704)
  4. Got 15 "thank you" clicks: #82528 (tragmich), #83339 (webppl)
  5. Got 14 "thank you" clicks: #83462 (tragmich)
  6. Got 12 "thank you" clicks: #82579 (tragmich), #82666 (pefemti), #82846 (kangquasar)
  7. Got 11 "thank you" clicks: #82472 (tengal123), #82814 (brucebarnes), #82953 (atlantaguy), #83621 (liftfinder), #83806 (ffcarry3746)
  8. Got 9 "thank you" clicks: #82969 (Simba007), #83146 (roche)
  9. Got 8 "thank you" clicks: #82761 (lion), #83137 (poldo1965), #83356 (barca1983123), #83541 (liftfinder)
  10. Got 7 "thank you" clicks: #82301 (ganju90), #82465 (winniethebeer), #82516 (WarandWin), #82827 (xvall), #82831 (unknown), #83273 (webppl), #83275 (rwlm)
The 10 highest number of thanks received by a single (non-admin) member in April 2012:
  1. Got 224 "thank you" clicks: blauesau
  2. Got 171 "thank you" clicks: ffcarry3746
  3. Got 160 "thank you" clicks: ganju90
  4. Got 130 "thank you" clicks: wm1122
  5. Got 92 "thank you" clicks: ericfabre
  6. Got 54 "thank you" clicks: millmiller
  7. Got 53 "thank you" clicks: kangquasar
  8. Got 41 "thank you" clicks: webppl
  9. Got 40 "thank you" clicks: poldo1965
  10. Got 36 "thank you" clicks: rwlm
  1. Got 2645 "thank you" clicks: ganju90
  2. Got 2159 "thank you" clicks: blauesau
  3. Got 1817 "thank you" clicks: kangquasar
  4. Got 1650 "thank you" clicks: wm1122
  8. Got 590 "thank you" clicks: ericfabre
  9. Got 542 "thank you" clicks: poldo1965
  10. Got 541 "thank you" clicks: lionman
Old June 21st, 2012, 12:58   #78
5,455 Total
May 2012:
The top 10 F/F posts in May 2012:
  1. Got 24 "thank you" clicks: #84561 (millmiller), #85180 (ffcarry3746)
  2. Got 22 "thank you" clicks: #85406 (wm1122)
  3. Got 20 "thank you" clicks: #84232 (ffcarry3746), #84579 (marplity)
  4. Got 19 "thank you" clicks: #85425 (ericfabre)
  5. Got 18 "thank you" clicks: #84874 (dendrin), #85920 (ffcarry3746)
  6. Got 17 "thank you" clicks: #84167 (tragmich), #84477 (ffcarry3746), #84786 (ericfabre), #85053 (lifted)
  7. Got 16 "thank you" clicks: #84121 (ffcarry3746), #85290 (blauesau), #85353 (ericfabre), #85537 (dendrin), #85727 (blauesau)
  8. Got 15 "thank you" clicks: #84392 (millmiller), #84442 (tragmich), #85179 (ffcarry3746), #85747 (sam_neil), #85772 (delura)
  9. Got 14 "thank you" clicks: #84690 (tiger0008), #84743 (SDS)
  10. Got 13 "thank you" clicks: #84853 (ffcarry3746), #84860 (crazy_ots), #85383 (ffcarry3746), #85415 (tragmich), #85546 (kly_lin)
  10. Got 26 "thank you" clicks: #47695 (ganju90), #55534 (ganju90), #78876 (blauesau)
The top 10 F/M posts in May 2012:
  1. Got 30 "thank you" clicks: #84981 (lifted)
  2. Got 25 "thank you" clicks: #84715 (scrapped)
  3. Got 23 "thank you" clicks: #84701 (lifted)
  4. Got 22 "thank you" clicks: #85524 (lifted)
  5. Got 19 "thank you" clicks: #84821 (Brandfuchs)
  6. Got 16 "thank you" clicks: #85193 (cultru), #85539 (darky), #85587 (edalsole)
  7. Got 15 "thank you" clicks: #85445 (ericfabre)
  8. Got 14 "thank you" clicks: #84041 (dendrin)
  9. Got 13 "thank you" clicks: #84832 (papaki), #85745 (ffcarry3746)
  10. Got 12 "thank you" clicks: #84018 (ganju90), #85414 (tragmich), #85843 (greatlifting)
  2. Got 52 "thank you" clicks: #71164 (enrycento)
The 10 highest number of thanks received by a single (non-admin) member in May 2012:
  1. Got 295 "thank you" clicks: ffcarry3746
  2. Got 137 "thank you" clicks: goldendoggy
  3. Got 104 "thank you" clicks: blauesau
  4. Got 90 "thank you" clicks: ericfabre
  5. Got 86 "thank you" clicks: millmiller
  6. Got 82 "thank you" clicks: lionman
  7. Got 77 "thank you" clicks: ganju90
  8. Got 67 "thank you" clicks: crazy_ots
  9. Got 56 "thank you" clicks: greatlifting
  10. Got 55 "thank you" clicks: webppl
  1. Got 2730 "thank you" clicks: ganju90
  2. Got 2281 "thank you" clicks: blauesau
  3. Got 1822 "thank you" clicks: kangquasar
  4. Got 1679 "thank you" clicks: wm1122
  5. Got 1130 "thank you" clicks: geniuslb
  6. Got 1002 "thank you" clicks: gsr3032000
  7. Got 715 "thank you" clicks: pqowieus2000
  8. Got 693 "thank you" clicks: ericfabre
  9. Got 629 "thank you" clicks: ffcarry3746
  10. Got 623 "thank you" clicks: lionman
Old July 19th, 2012, 22:03   #79
ffcarry3746
ffcarry3746's Avatar
2,143 Total
june?
ffcarry3746 is offline
Old July 20th, 2012, 20:30   #80
5,455 Total
Thanks for the reminder.
June 2012:
The top 10 F/F posts in June 2012:
  1. Got 30 "thank you" clicks: #87620 (frontmann502)
  2. Got 26 "thank you" clicks: #86122 (ericfabre)
  3. Got 25 "thank you" clicks: #86569 (lifted), #87033 (wm1122)
  4. Got 23 "thank you" clicks: #86151 (kangquasar), #86269 (lifted)
  5. Got 21 "thank you" clicks: #86698 (LilMatty)
  6. Got 20 "thank you" clicks: #86333 (toshiba)
  7. Got 19 "thank you" clicks: #87085 (wm1122)
  8. Got 18 "thank you" clicks: #87019 (ericfabre), #87778 (wm1122)
  9. Got 17 "thank you" clicks: #86486 (dendrin), #86970 (soclope), #87384 (ffcarry3746), #87673 (tragmich), #87758 (ericfabre), #87901 (ffcarry3746)
  10. Got 16 "thank you" clicks: #87653 (mishamironovv)
  7. Got 30 "thank you" clicks: #68422 (explore9999), #87620 (frontmann502)
  9. Got 27 "thank you" clicks: #58787 (ganju90), #59918 (lunchbox682), #78876 (blauesau), #81633 (mishamironovv)
  10. Got 26 "thank you" clicks: #47695 (ganju90), #55534 (ganju90), #86122 (ericfabre)
The top 10 F/M posts in June 2012:
  1. Got 74 "thank you" clicks: #86828 (lifted)
  2. Got 51 "thank you" clicks: #86128 (lifted)
  3. Got 41 "thank you" clicks: #87319 (lifted)
  4. Got 31 "thank you" clicks: #86290 (lifted), #87481 (lifted), #87486 (Strike)
  5. Got 27 "thank you" clicks: #87169 (lifted)
  6. Got 26 "thank you" clicks: #87218 (bravesirrobin)
  7. Got 25 "thank you" clicks: #86816 (bravesirrobin), #87352 (kangquasar)
  8. Got 24 "thank you" clicks: #86817 (bravesirrobin)
  9. Got 23 "thank you" clicks: #86155 (kangquasar), #86846 (sam_neil), #87717 (lifted)
  10. Got 21 "thank you" clicks: #87217 (bravesirrobin)
  2. Got 62 "thank you" clicks: #47984 (ocatcher)
  3. Got 52 "thank you" clicks: #71164 (enrycento)
  4. Got 51 "thank you" clicks: #86128 (lifted)
  5. Got 46 "thank you" clicks: #47697 (ganju90)
  6. Got 44 "thank you" clicks: #81057 (Mike)
  7. Got 43 "thank you" clicks: #73881 (Bacha)
  8. Got 41 "thank you" clicks: #87319 (lifted)
  9. Got 39 "thank you" clicks: #78361 (goldendoggy)
  10. Got 38 "thank you" clicks: #55634 (ganju90)
The 10 highest number of thanks received by a single (non-admin) member in June 2012:
  1. Got 166 "thank you" clicks: kangquasar
  2. Got 126 "thank you" clicks: LilMatty
  3. Got 123 "thank you" clicks: ffcarry3746
  4. Got 111 "thank you" clicks: blauesau
  5. Got 108 "thank you" clicks: bravesirrobin, goldendoggy
  6. Got 96 "thank you" clicks: ericfabre
  7. Got 76 "thank you" clicks: qwer123
  8. Got 75 "thank you" clicks: wm1122
  9. Got 65 "thank you" clicks: lionman
  10. Got 60 "thank you" clicks: ganju90
  1. Got 2791 "thank you" clicks: ganju90
  2. Got 2400 "thank you" clicks: blauesau
  3. Got 1988 "thank you" clicks: kangquasar
  4. Got 1754 "thank you" clicks: wm1122
  7. Got 789 "thank you" clicks: ericfabre
  8. Got 754 "thank you" clicks: ffcarry3746
  9. Got 725 "thank you" clicks: pqowieus2000
  10. Got 689 "thank you" clicks: lionman
LilMatty (August 9th, 2012), ffcarry3746 (August 7th, 2012)
