Old August 5th, 2012, 20:45   #81
5,519 Total
The July list will be delayed due to technical issues.
Old August 18th, 2012, 08:59   #82
5,519 Total
Better late than never:
July 2012:
The top 10 F/F posts in July 2012:
  1. Got 33 "thank you" clicks: #90114 (blauesau)
  2. Got 30 "thank you" clicks: #89050 (lucky_9277)
  3. Got 23 "thank you" clicks: #89291 (kangquasar)
  4. Got 20 "thank you" clicks: #90310 (wm1122)
  5. Got 19 "thank you" clicks: #90291 (helter)
  6. Got 18 "thank you" clicks: #89225 (themasterkavar), #89359 (ffcarry3746)
  7. Got 17 "thank you" clicks: #88095 (perun ffcarries), #88858 (ffcarry3746)
  8. Got 16 "thank you" clicks: #89525 (dendrin), #89990 (blauesau)
  9. Got 15 "thank you" clicks: #88993 (Pickboy100), #89117 (Leobor), #89126 (perun ffcarries), #89700 (kly_lin), #89843 (kangquasar), #89858 (wm1122)
  10. Got 14 "thank you" clicks: #89984 (ashok)
The top 10 F/F posts since the post ratings started:
  1. Got 37 "thank you" clicks: #56223 (ganju90), #68214 (explore9999), #73169 (dendrin), #75014 (mishamironovv)
  2. Got 36 "thank you" clicks: #56417 (ganju90)
  3. Got 35 "thank you" clicks: #76416 (ponyplay)
  4. Got 34 "thank you" clicks: #64265 (dendrin)
  5. Got 33 "thank you" clicks: #90114 (blauesau)
  6. Got 32 "thank you" clicks: #61136 (wm1122)
  7. Got 31 "thank you" clicks: #76520 (dendrin)
  8. Got 30 "thank you" clicks: #68422 (explore9999), #87620 (frontmann502), #89050 (lucky_9277)
  9. Got 28 "thank you" clicks: #78584 (wm1122)
  10. Got 27 "thank you" clicks: #58787 (ganju90), #59918 (lunchbox682), #78876 (blauesau), #81633 (mishamironovv)
The top 10 F/M posts in July 2012:
  1. Got 28 "thank you" clicks: #90048 (poldo1965)
  2. Got 26 "thank you" clicks: #89839 (kangquasar)
  3. Got 25 "thank you" clicks: #88457 (umberto)
  4. Got 22 "thank you" clicks: #88581 (tragmich)
  5. Got 21 "thank you" clicks: #89670 (bravesirrobin)
  6. Got 20 "thank you" clicks: #88419 (mpaneole)
  7. Got 19 "thank you" clicks: #89033 (cultru)
  8. Got 18 "thank you" clicks: #88272 (kangquasar), #89129 (schuster007)
  9. Got 17 "thank you" clicks: #88344 (gimmi695), #89522 (Yeahman)
  10. Got 15 "thank you" clicks: #87932 (flexfan)
The top 10 F/M posts since the post ratings started:
  1. Got 62 "thank you" clicks: #47984 (ocatcher)
  2. Got 52 "thank you" clicks: #71164 (enrycento)
  3. Got 46 "thank you" clicks: #47697 (ganju90)
  4. Got 44 "thank you" clicks: #81057 (Mike)
  5. Got 43 "thank you" clicks: #73881 (Bacha)
  6. Got 39 "thank you" clicks: #78361 (goldendoggy)
  7. Got 38 "thank you" clicks: #55634 (ganju90)
  8. Got 37 "thank you" clicks: #74514 (gsr3032000)
  9. Got 36 "thank you" clicks: #55429 (ganju90)
  10. Got 35 "thank you" clicks: #43994 (filmguy), #58616 (ganju90), #78586 (wm1122)
The 10 highest number of thanks received by a single (non-admin) member in July 2012:
  1. Got 204 "thank you" clicks: kangquasar
  2. Got 188 "thank you" clicks: ffcarry3746
  3. Got 130 "thank you" clicks: blauesau
  4. Got 68 "thank you" clicks: poldo1965
  5. Got 64 "thank you" clicks: toonboek
  6. Got 63 "thank you" clicks: goldendoggy
  7. Got 60 "thank you" clicks: qwer123
  8. Got 54 "thank you" clicks: Yeahman
  9. Got 52 "thank you" clicks: kly_lin
  10. Got 45 "thank you" clicks: choicecourage
The 10 highest number of thanks received by a single (non-admin) member since the post ratings started:
  1. Got 2819 "thank you" clicks: ganju90
  2. Got 2538 "thank you" clicks: blauesau
  3. Got 2195 "thank you" clicks: kangquasar
  4. Got 1791 "thank you" clicks: wm1122
  5. Got 1130 "thank you" clicks: geniuslb
  6. Got 1038 "thank you" clicks: gsr3032000
  7. Got 944 "thank you" clicks: ffcarry3746
  8. Got 815 "thank you" clicks: ericfabre
  9. Got 740 "thank you" clicks: pqowieus2000
  10. Got 711 "thank you" clicks: lionman, poldo1965
ffcarry3746 (August 25th, 2012)
Old September 16th, 2012, 17:26   #83
ffcarry3746
ffcarry3746's Avatar
2,146 Total
aguest plz
ffcarry3746 is offline
Old September 16th, 2012, 18:29   #84
5,519 Total
It's a good thing at least one of us is paying attention ffcarry.
August 2012:
The top 10 F/F posts in August 2012:
  1. Got 38 "thank you" clicks: #91371 (blauesau)
  2. Got 28 "thank you" clicks: #90481 (dendrin)
  3. Got 25 "thank you" clicks: #91750 (egefaloz)
  4. Got 21 "thank you" clicks: #91173 (ganju90)
  5. Got 20 "thank you" clicks: #90824 (ffcarry3746), #90969 (tragmich)
  6. Got 19 "thank you" clicks: #91691 (wm1122), #91852 (ffcarry3746)
  7. Got 18 "thank you" clicks: #90821 (ffcarry3746)
  8. Got 17 "thank you" clicks: #90475 (dendrin), #91057 (Borborygmus), #92040 (perun ffcarries)
  9. Got 16 "thank you" clicks: #90483 (dareman)
  10. Got 15 "thank you" clicks: #90462 (SDS), #90705 (ganju90), #90822 (ffcarry3746), #90863 (ganju90), #90892 (blauesau)
  2. Got 37 "thank you" clicks: #56223 (ganju90), #68214 (explore9999), #73169 (dendrin), #75014 (mishamironovv)
  3. Got 36 "thank you" clicks: #56417 (ganju90), #76416 (ponyplay), #90114 (blauesau)
  5. Got 32 "thank you" clicks: #61136 (wm1122)
  6. Got 31 "thank you" clicks: #68422 (explore9999), #76520 (dendrin)
  7. Got 30 "thank you" clicks: #87620 (frontmann502), #89050 (lucky_9277)
  8. Got 28 "thank you" clicks: #78584 (wm1122), #90481 (dendrin)
  9. Got 27 "thank you" clicks: #58787 (ganju90), #59918 (lunchbox682), #78876 (blauesau), #81633 (mishamironovv)
  10. Got 26 "thank you" clicks: #47695 (ganju90), #55534 (ganju90), #74899 (SDS), #86122 (ericfabre)
The top 10 F/M posts in August 2012:
  1. Got 23 "thank you" clicks: #90937 (mpaneole)
  2. Got 20 "thank you" clicks: #91345 (polda)
  3. Got 19 "thank you" clicks: #91289 (barca1983123), #91583 (bravesirrobin)
  4. Got 16 "thank you" clicks: #90391 (xi)
  5. Got 15 "thank you" clicks: #91234 (seanr), #91515 (gchand81)
  6. Got 14 "thank you" clicks: #91416 (raymond), #91648 (FinQ)
  7. Got 13 "thank you" clicks: #91227 (kangquasar), #91818 (greybeezer)
  8. Got 12 "thank you" clicks: #90958 (toonboek), #91187 (bravesirrobin)
  9. Got 11 "thank you" clicks: #90648 (vilik2003), #90826 (ffcarry3746), #91477 (seanr), #91582 (bravesirrobin)
  10. Got 10 "thank you" clicks: #91192 (goldendoggy), #91233 (westlife_100), #91300 (dasiotemo), #91445 (harsha4000)
The 10 highest number of thanks received by a single (non-admin) member in August 2012:
  1. Got 183 "thank you" clicks: ffcarry3746
  2. Got 133 "thank you" clicks: blauesau
  3. Got 90 "thank you" clicks: ganju90
  4. Got 76 "thank you" clicks: goldendoggy
  5. Got 72 "thank you" clicks: kangquasar
  6. Got 64 "thank you" clicks: seanr
  7. Got 57 "thank you" clicks: bravesirrobin
  8. Got 54 "thank you" clicks: shookston
  9. Got 44 "thank you" clicks: polda
  10. Got 43 "thank you" clicks: harsha4000
  1. Got 2928 "thank you" clicks: ganju90
  2. Got 2687 "thank you" clicks: blauesau
  3. Got 2271 "thank you" clicks: kangquasar
  4. Got 1818 "thank you" clicks: wm1122
  5. Got 1139 "thank you" clicks: geniuslb
  6. Got 1132 "thank you" clicks: ffcarry3746
  7. Got 1043 "thank you" clicks: gsr3032000
  8. Got 819 "thank you" clicks: ericfabre
  9. Got 758 "thank you" clicks: polda
  10. Got 744 "thank you" clicks: lionman
ffcarry3746 (September 18th, 2012)
Old October 2nd, 2012, 19:08   #85
5,519 Total
September 2012:
The top 10 F/F posts in September 2012:
  1. Got 41 "thank you" clicks: #93063 (wm1122)
  2. Got 34 "thank you" clicks: #93081 (blauesau)
  3. Got 33 "thank you" clicks: #92934 (mebalshaw)
  4. Got 31 "thank you" clicks: #92900 (wm1122), #92924 (mebalshaw)
  5. Got 27 "thank you" clicks: #92720 (mebalshaw), #92796 (mebalshaw)
  6. Got 24 "thank you" clicks: #92492 (Gf_24)
  7. Got 19 "thank you" clicks: #93839 (qwer123)
  8. Got 18 "thank you" clicks: #93128 (mebalshaw)
  9. Got 17 "thank you" clicks: #92901 (wm1122)
  10. Got 16 "thank you" clicks: #92518 (overheadlift), #92581 (qwer123), #92876 (tragmich), #93139 (mebalshaw), #94128 (ericfabre)
  2. Got 38 "thank you" clicks: #68214 (explore9999), #91371 (blauesau)
  3. Got 37 "thank you" clicks: #56223 (ganju90), #73169 (dendrin), #75014 (mishamironovv)
  4. Got 36 "thank you" clicks: #56417 (ganju90), #76416 (ponyplay), #90114 (blauesau)
  5. Got 34 "thank you" clicks: #64265 (dendrin), #93081 (blauesau)
  6. Got 33 "thank you" clicks: #92934 (mebalshaw)
  7. Got 32 "thank you" clicks: #61136 (wm1122), #68422 (explore9999)
  8. Got 31 "thank you" clicks: #76520 (dendrin), #92900 (wm1122), #92924 (mebalshaw)
  9. Got 30 "thank you" clicks: #87620 (frontmann502), #89050 (lucky_9277)
  10. Got 28 "thank you" clicks: #78584 (wm1122), #90481 (dendrin)
The top 10 F/M posts in September 2012:
  1. Got 39 "thank you" clicks: #92906 (wm1122)
  2. Got 34 "thank you" clicks: #92502 (ffcarry3746)
  3. Got 32 "thank you" clicks: #92903 (wm1122)
  4. Got 23 "thank you" clicks: #93574 (harsha4000)
  5. Got 22 "thank you" clicks: #92672 (tragmich)
  6. Got 21 "thank you" clicks: #93718 (millmiller)
  7. Got 20 "thank you" clicks: #93332 (pqowieus2000)
  8. Got 16 "thank you" clicks: #93334 (pqowieus2000), #93900 (kangquasar)
  9. Got 14 "thank you" clicks: #92753 (tallgirlfan), #93380 (tragmich)
  10. Got 13 "thank you" clicks: #92673 (cultru), #93343 (pqowieus2000), #93755 (asiacarry)
  6. Got 39 "thank you" clicks: #78361 (goldendoggy), #92906 (wm1122)
The 10 highest number of thanks received by a single (non-admin) member in September 2012:
  1. Got 164 "thank you" clicks: mebalshaw
  2. Got 160 "thank you" clicks: wm1122
  3. Got 125 "thank you" clicks: blauesau
  4. Got 92 "thank you" clicks: ericfabre
  5. Got 89 "thank you" clicks: ganju90
  6. Got 86 "thank you" clicks: pqowieus2000
  7. Got 85 "thank you" clicks: ffcarry3746
  8. Got 84 "thank you" clicks: lionman
  9. Got 76 "thank you" clicks: kangquasar
  10. Got 71 "thank you" clicks: harsha4000
  1. Got 3023 "thank you" clicks: ganju90
  2. Got 2817 "thank you" clicks: blauesau
  3. Got 2357 "thank you" clicks: kangquasar
  4. Got 1983 "thank you" clicks: wm1122
  5. Got 1222 "thank you" clicks: ffcarry3746
  6. Got 1152 "thank you" clicks: geniuslb
  7. Got 1070 "thank you" clicks: gsr3032000
  8. Got 912 "thank you" clicks: ericfabre
  9. Got 829 "thank you" clicks: pqowieus2000
  10. Got 828 "thank you" clicks: lionman
wm1122 (October 9th, 2012)
Old December 2nd, 2012, 21:46   #86
5,519 Total
Forgot about October's list...
October 2012:
The top 10 F/F posts in October 2012:
  1. Got 30 "thank you" clicks: #95414 (dendrin)
  2. Got 23 "thank you" clicks: #95586 (qwer123), #95867 (s04509), #96191 (qwer123)
  3. Got 22 "thank you" clicks: #96013 (SDS)
  4. Got 21 "thank you" clicks: #95373 (SDS)
  5. Got 20 "thank you" clicks: #94431 (Vlad), #95409 (qwer123), #95864 (Angeleye)
  6. Got 19 "thank you" clicks: #94537 (tragmich), #95494 (tragmich)
  7. Got 18 "thank you" clicks: #94377 (blauesau), #95008 (SDS)
  8. Got 17 "thank you" clicks: #96026 (tragmich)
  9. Got 15 "thank you" clicks: #94532 (ponyplay), #95653 (overheadlift), #96388 (tragmich)
  10. Got 14 "thank you" clicks: #94574 (xirgu20), #95642 (qwer123)
  1. Got 43 "thank you" clicks: #93063 (wm1122)
  3. Got 37 "thank you" clicks: #56223 (ganju90), #73169 (dendrin), #75014 (mishamironovv), #93081 (blauesau)
  6. Got 33 "thank you" clicks: #68422 (explore9999), #92934 (mebalshaw)
  7. Got 32 "thank you" clicks: #61136 (wm1122), #92924 (mebalshaw)
  9. Got 30 "thank you" clicks: #87620 (frontmann502), #89050 (lucky_9277), #95414 (dendrin)
The top 10 F/M posts in October 2012:
  1. Got 34 "thank you" clicks: #94748 (polda)
  2. Got 32 "thank you" clicks: #95020 (toonboek)
  3. Got 31 "thank you" clicks: #94994 (bsn0327)
  4. Got 30 "thank you" clicks: #95021 (toonboek)
  5. Got 28 "thank you" clicks: #96021 (toonboek)
  6. Got 27 "thank you" clicks: #95628 (anms06)
  7. Got 26 "thank you" clicks: #96020 (toonboek)
  8. Got 25 "thank you" clicks: #96018 (toonboek)
  9. Got 23 "thank you" clicks: #94896 (mullarky), #95568 (vilik2003)
  10. Got 22 "thank you" clicks: #94878 (toshiba), #96219 (kangquasar)
  6. Got 40 "thank you" clicks: #92906 (wm1122)
  7. Got 39 "thank you" clicks: #78361 (goldendoggy)
  8. Got 38 "thank you" clicks: #55634 (ganju90)
  9. Got 37 "thank you" clicks: #74514 (gsr3032000)
  10. Got 36 "thank you" clicks: #55429 (ganju90)
The 10 highest number of thanks received by a single (non-admin) member in October 2012:
  1. Got 186 "thank you" clicks: polda
  2. Got 171 "thank you" clicks: qwer123
  3. Got 162 "thank you" clicks: ganju90
  4. Got 160 "thank you" clicks: kangquasar
  5. Got 145 "thank you" clicks: toonboek
  6. Got 104 "thank you" clicks: xirgu20
  7. Got 99 "thank you" clicks: blauesau
  8. Got 89 "thank you" clicks: goldendoggy
  9. Got 64 "thank you" clicks: SDS
  10. Got 55 "thank you" clicks: bsn0327, lionman
  1. Got 3208 "thank you" clicks: ganju90
  2. Got 2939 "thank you" clicks: blauesau
  3. Got 2527 "thank you" clicks: kangquasar
  4. Got 1992 "thank you" clicks: wm1122
  5. Got 1235 "thank you" clicks: ffcarry3746
  6. Got 1162 "thank you" clicks: geniuslb
  7. Got 1074 "thank you" clicks: gsr3032000
  8. Got 1017 "thank you" clicks: polda
  9. Got 923 "thank you" clicks: ericfabre
  10. Got 893 "thank you" clicks: lionman
Old December 2nd, 2012, 21:50   #87
5,519 Total
November 2012:
The top 10 F/F posts in November 2012:
  1. Got 36 "thank you" clicks: #97430 (preacher860)
  2. Got 29 "thank you" clicks: #97205 (ennamorado)
  3. Got 26 "thank you" clicks: #96910 (wm1122)
  4. Got 24 "thank you" clicks: #96585 (ganju90), #97470 (carloshenrique)
  5. Got 22 "thank you" clicks: #98161 (blauesau)
  6. Got 21 "thank you" clicks: #98261 (perun ffcarries)
  7. Got 20 "thank you" clicks: #97130 (qwer123), #98039 (SDS), #98283 (SDS)
  8. Got 19 "thank you" clicks: #97261 (tragmich)
  9. Got 18 "thank you" clicks: #97354 (nautilus), #97423 (preacher860)
  10. Got 17 "thank you" clicks: #97220 (nautilus), #97501 (dendrin), #97710 (schuster007), #97791 (dendrin)
  4. Got 36 "thank you" clicks: #56417 (ganju90), #76416 (ponyplay), #90114 (blauesau), #97430 (preacher860)
  10. Got 29 "thank you" clicks: #97205 (ennamorado)
The top 10 F/M posts in November 2012:
  2. Got 32 "thank you" clicks: #96916 (Coolbeans)
  3. Got 29 "thank you" clicks: #98175 (namledn)
  4. Got 25 "thank you" clicks: #97352 (nautilus)
  5. Got 21 "thank you" clicks: #96882 (phoneman)
  6. Got 20 "thank you" clicks: #96716 (wismer85)
  7. Got 19 "thank you" clicks: #96861 (ateam81353)
  8. Got 18 "thank you" clicks: #96929 (tragmich), #97423 (preacher860)
  9. Got 17 "thank you" clicks: #97357 (xirgu20), #98274 (xirgu20)
  10. Got 16 "thank you" clicks: #96539 (arcang7)
  10. Got 36 "thank you" clicks: #55429 (ganju90), #97430 (preacher860)
The 10 highest number of thanks received by a single (non-admin) member in November 2012:
  1. Got 166 "thank you" clicks: ennamorado
  2. Got 142 "thank you" clicks: gchand81
  3. Got 141 "thank you" clicks: ganju90
  4. Got 119 "thank you" clicks: nautilus
  5. Got 116 "thank you" clicks: blauesau
  6. Got 110 "thank you" clicks: xirgu20
  7. Got 88 "thank you" clicks: polda
  8. Got 81 "thank you" clicks: shanu
  9. Got 75 "thank you" clicks: namledn
  10. Got 70 "thank you" clicks: qwer123
  1. Got 3349 "thank you" clicks: ganju90
  2. Got 3055 "thank you" clicks: blauesau
  4. Got 2031 "thank you" clicks: wm1122
  5. Got 1248 "thank you" clicks: ffcarry3746
  7. Got 1105 "thank you" clicks: polda
  8. Got 1074 "thank you" clicks: gsr3032000
  9. Got 925 "thank you" clicks: ericfabre
  10. Got 922 "thank you" clicks: lionman
Old January 8th, 2013, 19:59   #88
5,519 Total
December 2012:
The top 10 F/F posts in December 2012:
  1. Got 24 "thank you" clicks: #99217 (JSimoni), #100547 (tragmich), #100590 (tragmich)
  2. Got 23 "thank you" clicks: #100337 (namledn), #100580 (overheadlift)
  3. Got 22 "thank you" clicks: #100111 (blauesau)
  4. Got 21 "thank you" clicks: #100513 (tragmich)
  5. Got 20 "thank you" clicks: #99493 (ganju90), #99758 (dendrin), #100215 (gchand81)
  6. Got 19 "thank you" clicks: #98815 (blauesau), #100110 (blauesau)
  7. Got 18 "thank you" clicks: #99131 (kangquasar), #100167 (overheadlift), #100268 (kangquasar), #100544 (tragmich)
  8. Got 17 "thank you" clicks: #99529 (tragmich)
  9. Got 16 "thank you" clicks: #99218 (JSimoni), #99811 (web_surfer)
  10. Got 15 "thank you" clicks: #99292 (dendrin), #99760 (TheWolfe)
  2. Got 39 "thank you" clicks: #91371 (blauesau), #93081 (blauesau)
  3. Got 38 "thank you" clicks: #68214 (explore9999), #73169 (dendrin), #76416 (ponyplay)
  4. Got 37 "thank you" clicks: #56223 (ganju90), #75014 (mishamironovv), #90114 (blauesau), #97430 (preacher860)
  5. Got 36 "thank you" clicks: #56417 (ganju90)
  6. Got 34 "thank you" clicks: #64265 (dendrin), #92934 (mebalshaw)
  7. Got 33 "thank you" clicks: #68422 (explore9999), #92924 (mebalshaw)
  8. Got 32 "thank you" clicks: #61136 (wm1122), #76520 (dendrin), #92900 (wm1122), #95414 (dendrin)
  9. Got 30 "thank you" clicks: #87620 (frontmann502), #89050 (lucky_9277), #92796 (mebalshaw), #97205 (ennamorado)
  10. Got 29 "thank you" clicks: #78584 (wm1122), #90481 (dendrin)
The top 10 F/M posts in December 2012:
  1. Got 32 "thank you" clicks: #100382 (xirgu20)
  2. Got 29 "thank you" clicks: #100839 (xirgu20)
  3. Got 28 "thank you" clicks: #99700 (pqowieus2000), #100257 (kangquasar)
  4. Got 27 "thank you" clicks: #100332 (tragmich)
  5. Got 26 "thank you" clicks: #99132 (kangquasar), #100181 (forevernow)
  6. Got 21 "thank you" clicks: #99583 (gchand81)
  7. Got 20 "thank you" clicks: #98956 (toonboek), #99721 (TheWolfe)
  8. Got 19 "thank you" clicks: #99365 (liftmealot)
  9. Got 18 "thank you" clicks: #98779 (goldendoggy), #100121 (darky), #100569 (mpaneole)
  10. Got 17 "thank you" clicks: #99725 (Montyrana)
  2. Got 53 "thank you" clicks: #71164 (enrycento)
  9. Got 37 "thank you" clicks: #74514 (gsr3032000), #97430 (preacher860)
The 10 highest number of thanks received by a single (non-admin) member in December 2012:
  1. Got 215 "thank you" clicks: gchand81
  2. Got 204 "thank you" clicks: blauesau, namledn
  3. Got 202 "thank you" clicks: kangquasar
  4. Got 100 "thank you" clicks: pqowieus2000
  5. Got 98 "thank you" clicks: ganju90
  6. Got 85 "thank you" clicks: xirgu20
  7. Got 76 "thank you" clicks: gondor300
  8. Got 73 "thank you" clicks: goldendoggy
  9. Got 61 "thank you" clicks: TheWolfe, tiger0008
  10. Got 56 "thank you" clicks: rwlm
  1. Got 3474 "thank you" clicks: ganju90
  2. Got 3349 "thank you" clicks: blauesau
  3. Got 2787 "thank you" clicks: kangquasar
  4. Got 2075 "thank you" clicks: wm1122
  5. Got 1291 "thank you" clicks: ffcarry3746
  6. Got 1180 "thank you" clicks: polda
  7. Got 1175 "thank you" clicks: geniuslb
  9. Got 943 "thank you" clicks: pqowieus2000
  10. Got 933 "thank you" clicks: ericfabre
Old February 4th, 2013, 18:03   #89
5,519 Total
January 2013:
The top 10 F/F posts in January 2013:
  1. Got 49 "thank you" clicks: #102746 (siihxh)
  2. Got 37 "thank you" clicks: #102627 (siihxh)
  3. Got 27 "thank you" clicks: #101472 (pokerstick)
  4. Got 26 "thank you" clicks: #102925 (siihxh)
  5. Got 25 "thank you" clicks: #101073 (wm1122), #101923 (tragmich), #102408 (qwer123)
  6. Got 24 "thank you" clicks: #102337 (pokerstick)
  7. Got 23 "thank you" clicks: #102241 (perun ffcarries)
  8. Got 20 "thank you" clicks: #101640 (namledn), #101928 (SDS), #102547 (egefaloz)
  9. Got 19 "thank you" clicks: #101051 (Vlad), #101315 (dendrin), #101683 (winniethebeer), #102147 (joanml05)
  10. Got 18 "thank you" clicks: #101385 (phoneman), #102175 (blauesau)
  2. Got 43 "thank you" clicks: #93063 (wm1122)
  3. Got 39 "thank you" clicks: #91371 (blauesau), #93081 (blauesau)
  4. Got 38 "thank you" clicks: #68214 (explore9999), #73169 (dendrin), #76416 (ponyplay), #97430 (preacher860)
  5. Got 37 "thank you" clicks: #56223 (ganju90), #75014 (mishamironovv), #90114 (blauesau), #102627 (siihxh)
  6. Got 36 "thank you" clicks: #56417 (ganju90)
  7. Got 34 "thank you" clicks: #64265 (dendrin), #92924 (mebalshaw), #92934 (mebalshaw)
  8. Got 33 "thank you" clicks: #68422 (explore9999)
  9. Got 32 "thank you" clicks: #61136 (wm1122), #76520 (dendrin), #92900 (wm1122), #95414 (dendrin)
  10. Got 30 "thank you" clicks: #87620 (frontmann502), #89050 (lucky_9277), #92796 (mebalshaw), #97205 (ennamorado)
The top 10 F/M posts in January 2013:
  1. Got 57 "thank you" clicks: #102792 (siihxh)
  2. Got 33 "thank you" clicks: #101192 (xirgu20)
  3. Got 30 "thank you" clicks: #103074 (siihxh)
  4. Got 29 "thank you" clicks: #102928 (siihxh)
  5. Got 28 "thank you" clicks: #102435 (carloshenrique)
  6. Got 27 "thank you" clicks: #101473 (pokerstick), #102464 (farfar)
  7. Got 25 "thank you" clicks: #101898 (xirgu20)
  8. Got 21 "thank you" clicks: #102157 (lion)
  9. Got 19 "thank you" clicks: #102486 (Montyrana)
  10. Got 17 "thank you" clicks: #101012 (namledn), #101929 (polda)
  2. Got 57 "thank you" clicks: #102792 (siihxh)
  3. Got 54 "thank you" clicks: #71164 (enrycento)
  4. Got 46 "thank you" clicks: #47697 (ganju90)
  5. Got 44 "thank you" clicks: #81057 (Mike)
  6. Got 43 "thank you" clicks: #73881 (Bacha)
  7. Got 40 "thank you" clicks: #92906 (wm1122)
  8. Got 39 "thank you" clicks: #78361 (goldendoggy)
  9. Got 38 "thank you" clicks: #55634 (ganju90), #97430 (preacher860)
  10. Got 37 "thank you" clicks: #74514 (gsr3032000)
The 10 highest number of thanks received by a single (non-admin) member in January 2013:
  1. Got 248 "thank you" clicks: siihxh
  2. Got 209 "thank you" clicks: namledn
  3. Got 183 "thank you" clicks: Montyrana
  4. Got 180 "thank you" clicks: blauesau
  5. Got 123 "thank you" clicks: erico
  6. Got 120 "thank you" clicks: wm1122
  7. Got 96 "thank you" clicks: pokerstick
  8. Got 94 "thank you" clicks: gchand81
  9. Got 89 "thank you" clicks: winniethebeer
  10. Got 85 "thank you" clicks: gondor300
  1. Got 3541 "thank you" clicks: ganju90
  2. Got 3536 "thank you" clicks: blauesau
  3. Got 2803 "thank you" clicks: kangquasar
  4. Got 2198 "thank you" clicks: wm1122
  5. Got 1296 "thank you" clicks: ffcarry3746
  6. Got 1263 "thank you" clicks: polda
  7. Got 1176 "thank you" clicks: geniuslb
  8. Got 1082 "thank you" clicks: gsr3032000
  9. Got 963 "thank you" clicks: pqowieus2000
  10. Got 936 "thank you" clicks: ericfabre
Old March 2nd, 2013, 17:24   #90
5,519 Total
February 2013:
The top 10 F/F posts in February 2013:
  1. Got 40 "thank you" clicks: #104417 (siihxh)
  2. Got 38 "thank you" clicks: #103538 (siihxh)
  3. Got 35 "thank you" clicks: #104206 (explore9999)
  4. Got 33 "thank you" clicks: #103190 (siihxh)
  5. Got 32 "thank you" clicks: #103224 (vilik2003), #103463 (siihxh)
  6. Got 31 "thank you" clicks: #104215 (enrycento)
  7. Got 30 "thank you" clicks: #104169 (SDS)
  8. Got 26 "thank you" clicks: #104233 (dendrin)
  9. Got 22 "thank you" clicks: #104141 (tragmich), #104303 (explore9999)
  10. Got 21 "thank you" clicks: #103675 (wm1122)
  1. Got 52 "thank you" clicks: #102746 (siihxh)
  3. Got 40 "thank you" clicks: #104417 (siihxh)
  4. Got 39 "thank you" clicks: #91371 (blauesau), #93081 (blauesau)
  5. Got 38 "thank you" clicks: #68214 (explore9999), #73169 (dendrin), #76416 (ponyplay), #97430 (preacher860), #102627 (siihxh), #103538 (siihxh)
  6. Got 37 "thank you" clicks: #56223 (ganju90), #75014 (mishamironovv), #90114 (blauesau)
  7. Got 36 "thank you" clicks: #56417 (ganju90)
  8. Got 35 "thank you" clicks: #104206 (explore9999)
  9. Got 34 "thank you" clicks: #64265 (dendrin), #92924 (mebalshaw), #92934 (mebalshaw)
  10. Got 33 "thank you" clicks: #68422 (explore9999), #103190 (siihxh)
The top 10 F/M posts in February 2013:
  1. Got 33 "thank you" clicks: #103397 (1qaz2wsx)
  2. Got 26 "thank you" clicks: #103247 (xirgu20)
  3. Got 21 "thank you" clicks: #103830 (namledn), #104143 (xirgu20)
  4. Got 19 "thank you" clicks: #103578 (barca1983123)
  5. Got 18 "thank you" clicks: #103267 (anms06), #104554 (xirgu20)
  6. Got 17 "thank you" clicks: #103721 (1qaz2wsx), #104649 (haiwan)
  7. Got 16 "thank you" clicks: #103663 (sultanroma), #103705 (Montyrana), #104647 (kangquasar)
  8. Got 15 "thank you" clicks: #103781 (tsukiaio), #103925 (gchand81), #104410 (tragmich)
  9. Got 14 "thank you" clicks: #104382 (namledn), #104434 (seanr)
  10. Got 13 "thank you" clicks: #103598 (erico), #104296 (goldendoggy), #104379 (strut170222), #104552 (tragmich)
  1. Got 65 "thank you" clicks: #102792 (siihxh)
  2. Got 62 "thank you" clicks: #47984 (ocatcher)
  7. Got 41 "thank you" clicks: #92906 (wm1122), #103074 (siihxh)
The 10 highest number of thanks received by a single (non-admin) member in February 2013:
  1. Got 164 "thank you" clicks: siihxh
  2. Got 123 "thank you" clicks: namledn
  3. Got 84 "thank you" clicks: xirgu20
  4. Got 75 "thank you" clicks: ganju90
  5. Got 72 "thank you" clicks: 1qaz2wsx
  6. Got 69 "thank you" clicks: explore9999
  7. Got 68 "thank you" clicks: kangquasar
  8. Got 61 "thank you" clicks: winniethebeer
  9. Got 60 "thank you" clicks: tiger0008
  10. Got 58 "thank you" clicks: qwer123
  1. Got 3621 "thank you" clicks: ganju90
  2. Got 3585 "thank you" clicks: blauesau
  3. Got 2876 "thank you" clicks: kangquasar
  4. Got 2241 "thank you" clicks: wm1122
  5. Got 1308 "thank you" clicks: polda
  6. Got 1298 "thank you" clicks: ffcarry3746
  7. Got 1178 "thank you" clicks: geniuslb
  9. Got 966 "thank you" clicks: ericfabre
  10. Got 964 "thank you" clicks: pqowieus2000
