Old August 3rd, 2016, 10:48   #121
Waiting for the Monthly Top 10 List.
Old August 3rd, 2016, 17:49   #122
5,519 Total
It doesn't appear that many people miss them when I don't post them, so I'm wondering if it's worth continuing this. After all, it's easy to sort posts by thanks score using http://landcforum.com/forums/sort_by_thanks.php, so the top 10 lists aren't as useful as they once were.
Old August 3rd, 2016, 18:03   #123
buddyochoa2
63 Total
I don't have permission to view that page :/
buddyochoa2 is offline
Old August 3rd, 2016, 18:11   #124
Originally Posted by dp View Post
It doesn't appear that many people miss them when I don't post them, so I'm wondering if it's worth continuing this. After all, it's easy to sort posts by thanks score using http://landcforum.com/forums/sort_by_thanks.php, so the top 10 lists aren't as useful as the once were.
Still in my opinion you must continue with it. Its better managed the way you used to put it. It will be nice if you can continue with it.
Old August 3rd, 2016, 21:18   #125
9 For This Post
5,519 Total
Now that you mention it, I think that feature is for VIP members, as a little reward for their contributions to the forum. You should apply for VIP though, a quick glance at your post and thanks count indicates that you probably qualify. You can request a VIP promotion in this thread: http://landcforum.com/forums/showthread.php?t=242
Let's see how many still care about the lists. Vote with the thanks button. If this post gets a decent number of thanks from active members, I will keep making the lists.
Juusi (September 14th, 2018), Chaza (August 23rd, 2016), deanie83 (August 5th, 2016), 5supermb (August 5th, 2016), spirited_667 (August 5th, 2016), Akshayb (August 4th, 2016), (August 4th, 2016), buddyochoa2 (August 3rd, 2016), aedgar (August 3rd, 2016)
Old August 14th, 2016, 11:52   #126
5,519 Total
OK, there are still some people that care about the top 10 lists. Here you go:
April 2016:
The top 10 F/F posts in April 2016:
  1. Got 48 "thank you" clicks: #176086 (mr.Lift)
  2. Got 41 "thank you" clicks: #176128 (Jojo)
  3. Got 30 "thank you" clicks: #174793 (ponyplay), #174994 (ponyplay), #175734 (llcc45)
  4. Got 29 "thank you" clicks: #174651 (mebalshaw), #175262 (ponyplay)
  5. Got 28 "thank you" clicks: #175814 (qwer123)
  6. Got 26 "thank you" clicks: #174897 (ponyplay), #174930 (ponyplay)
  7. Got 24 "thank you" clicks: #175692 (ponyplay), #175858 (dendrin), #175968 (dendrin)
  8. Got 23 "thank you" clicks: #174790 (pefemti), #176111 (wm1122), #176112 (wm1122)
  9. Got 22 "thank you" clicks: #175600 (5supermb)
  10. Got 21 "thank you" clicks: #174830 (wm1122), #174928 (ponyplay), #175047 (moorman01), #175502 (Angeleye)
The top 10 F/F posts since the post ratings started:
  1. Got 74 "thank you" clicks: #144353 (templebevelle)
  2. Got 67 "thank you" clicks: #145296 (templebevelle)
  3. Got 58 "thank you" clicks: #129570 (kangquasar)
  4. Got 53 "thank you" clicks: #102746 (siihxh)
  5. Got 52 "thank you" clicks: #108594 (tragmich)
  6. Got 50 "thank you" clicks: #117591 (wm1122), #153163 (kurtan)
  7. Got 48 "thank you" clicks: #176086 (mr.Lift)
  8. Got 45 "thank you" clicks: #106603 (siihxh)
  9. Got 44 "thank you" clicks: #105348 (siihxh), #137509 (blauesau)
  10. Got 43 "thank you" clicks: #93063 (wm1122), #104417 (siihxh), #107948 (schuster007), #133529 (dendrin), #169369 (JSimoni)
The top 10 F/M posts in April 2016:
  1. Got 40 "thank you" clicks: #175315 (arav1605)
  2. Got 35 "thank you" clicks: #175567 (enrycento)
  3. Got 34 "thank you" clicks: #175043 (nonsense)
  4. Got 33 "thank you" clicks: #175449 (Meagdi), #175529 (Jojo), #176125 (Jojo)
  5. Got 31 "thank you" clicks: #175815 (qwer123)
  6. Got 26 "thank you" clicks: #175495 (lenny)
  7. Got 25 "thank you" clicks: #175494 (Mehta90)
  8. Got 24 "thank you" clicks: #175746 (vilik2003)
  9. Got 22 "thank you" clicks: #175210 (Bacha), #175316 (arav1605)
  10. Got 20 "thank you" clicks: #175517 (Jojo), #175632 (Meagdi)
The top 10 F/M posts since the post ratings started:
  1. Got 109 "thank you" clicks: #150223 (katsou21)
  2. Got 107 "thank you" clicks: #143256 (skyfall2013)
  3. Got 76 "thank you" clicks: #146101 (Bmiles90)
  4. Got 68 "thank you" clicks: #102792 (siihxh)
  5. Got 66 "thank you" clicks: #158021 (lion)
  6. Got 63 "thank you" clicks: #47984 (ocatcher), #172729 (namledn)
  7. Got 58 "thank you" clicks: #151040 (Bacha)
  8. Got 57 "thank you" clicks: #150289 (dendrin)
  9. Got 56 "thank you" clicks: #71164 (enrycento)
  10. Got 53 "thank you" clicks: #113310 (wm1122), #170671 (enrycento)
The 10 highest number of thanks received by a single (non-admin) member in April 2016:
  1. Got 397 "thank you" clicks: Jojo
  2. Got 227 "thank you" clicks: Bmiles90
  3. Got 167 "thank you" clicks: Angeleye
  4. Got 157 "thank you" clicks: ganju90
  5. Got 111 "thank you" clicks: pqowieus2000
  6. Got 108 "thank you" clicks: kurtan
  7. Got 100 "thank you" clicks: arav1605
  8. Got 96 "thank you" clicks: wm1122
  9. Got 87 "thank you" clicks: qwer123
  10. Got 85 "thank you" clicks: wondering
The 10 highest number of thanks received by a single (non-admin) member since the post ratings started:
  1. Got 9065 "thank you" clicks: ganju90
  2. Got 7418 "thank you" clicks: Bmiles90
  3. Got 7218 "thank you" clicks: kangquasar
  4. Got 5992 "thank you" clicks: blauesau
  5. Got 4697 "thank you" clicks: winniethebeer
  6. Got 4670 "thank you" clicks: qwer123
  7. Got 3953 "thank you" clicks: namledn
  8. Got 3929 "thank you" clicks: wm1122
  9. Got 3517 "thank you" clicks: tiger0008
  10. Got 3259 "thank you" clicks: Angeleye
May 2016:
The top 10 F/F posts in May 2016:
  1. Got 46 "thank you" clicks: #176519 (tiptoeriot)
  2. Got 41 "thank you" clicks: #177103 (mr.Lift)
  3. Got 34 "thank you" clicks: #177740 (qwer123)
  4. Got 33 "thank you" clicks: #176243 (SDS)
  5. Got 28 "thank you" clicks: #176675 (mr.Lift)
  6. Got 26 "thank you" clicks: #176626 (ganju90)
  7. Got 25 "thank you" clicks: #176672 (wm1122), #176708 (kurtan), #177066 (Jojo)
  8. Got 24 "thank you" clicks: #176455 (dareman), #177576 (nautilus)
  9. Got 23 "thank you" clicks: #177147 (wondering)
  10. Got 22 "thank you" clicks: #177291 (tiger0008)
  8. Got 46 "thank you" clicks: #176519 (tiptoeriot)
  9. Got 45 "thank you" clicks: #106603 (siihxh)
  10. Got 44 "thank you" clicks: #105348 (siihxh), #137509 (blauesau)
The top 10 F/M posts in May 2016:
  1. Got 31 "thank you" clicks: #177067 (Jojo)
  2. Got 29 "thank you" clicks: #176754 (winniethebeer)
  3. Got 22 "thank you" clicks: #177448 (Janhruska)
  4. Got 20 "thank you" clicks: #176359 (pickmeup9), #176727 (spiershake), #176959 (xtc), #177326 (piggybackrides)
  5. Got 18 "thank you" clicks: #176394 (Jojo), #176895 (Bmiles90)
  6. Got 17 "thank you" clicks: #176201 (Jojo), #176625 (ganju90), #177157 (meierkopp), #177390 (john_smith_1965)
  7. Got 16 "thank you" clicks: #176648 (piggybackrides), #176764 (Jojo), #176923 (thracian), #177252 (Far)
  8. Got 15 "thank you" clicks: #176585 (Jojo), #177268 (meierkopp)
  9. Got 14 "thank you" clicks: #177558 (piggybackrides), #177567 (gimmi695), #177725 (Akshayb)
  10. Got 13 "thank you" clicks: #176251 (Bmiles90), #176775 (Bacha), #177529 (g.gupta1980), #177714 (Jojo)
The 10 highest number of thanks received by a single (non-admin) member in May 2016:
  1. Got 410 "thank you" clicks: Bmiles90
  2. Got 344 "thank you" clicks: Jojo
  3. Got 290 "thank you" clicks: ganju90
  4. Got 119 "thank you" clicks: please598
  5. Got 115 "thank you" clicks: mr.Lift
  6. Got 109 "thank you" clicks: tiptoeriot
  7. Got 101 "thank you" clicks: Akshayb
  8. Got 92 "thank you" clicks: wm1122
  9. Got 90 "thank you" clicks: qwer123
  10. Got 84 "thank you" clicks: piggybackrides
  1. Got 9355 "thank you" clicks: ganju90
  2. Got 7828 "thank you" clicks: Bmiles90
  3. Got 7287 "thank you" clicks: kangquasar
  5. Got 4760 "thank you" clicks: qwer123, winniethebeer
  6. Got 4021 "thank you" clicks: wm1122
  7. Got 4005 "thank you" clicks: namledn
  8. Got 3594 "thank you" clicks: tiger0008
  9. Got 3315 "thank you" clicks: Angeleye
  10. Got 3032 "thank you" clicks: lionman
June 2016:
The top 10 F/F posts in June 2016:
  1. Got 40 "thank you" clicks: #177988 (henryspencer)
  2. Got 31 "thank you" clicks: #178694 (kantaja)
  3. Got 30 "thank you" clicks: #178032 (perun ffcarries), #178959 (perun ffcarries)
  4. Got 28 "thank you" clicks: #178853 (mankan77)
  5. Got 27 "thank you" clicks: #177790 (winniethebeer)
  6. Got 25 "thank you" clicks: #178850 (mankan77)
  7. Got 24 "thank you" clicks: #178787 (ponyplay), #178820 (ericfabre)
  8. Got 22 "thank you" clicks: #178480 (tiptoeriot)
  9. Got 21 "thank you" clicks: #177879 (kangquasar)
  10. Got 20 "thank you" clicks: #177869 (CageDemon), #178915 (vanberg22)
The top 10 F/M posts in June 2016:
  1. Got 39 "thank you" clicks: #178566 (Jojo)
  2. Got 35 "thank you" clicks: #177782 (liftmeup78)
  3. Got 30 "thank you" clicks: #178872 (lion)
  4. Got 25 "thank you" clicks: #178143 (xirgu20)
  5. Got 22 "thank you" clicks: #179425 (Angeleye)
  6. Got 19 "thank you" clicks: #179009 (lion)
  7. Got 18 "thank you" clicks: #178173 (vilik2003), #178549 (kangquasar), #178563 (Jojo)
  8. Got 17 "thank you" clicks: #178090 (cx), #178154 (MGP), #178848 (Bacha), #179087 (kangquasar), #179131 (cx), #179138 (kangquasar)
  9. Got 16 "thank you" clicks: #178147 (cx), #178594 (winniethebeer)
  10. Got 15 "thank you" clicks: #178232 (lion), #178624 (nonsense), #178763 (lion), #178788 (meierkopp), #179132 (cx), #179179 (asshunter), #179380 (wismer85)
The 10 highest number of thanks received by a single (non-admin) member in June 2016:
  1. Got 356 "thank you" clicks: kangquasar
  2. Got 252 "thank you" clicks: Bmiles90
  3. Got 202 "thank you" clicks: ganju90
  4. Got 170 "thank you" clicks: cx
  5. Got 166 "thank you" clicks: Angeleye
  6. Got 165 "thank you" clicks: lion
  7. Got 128 "thank you" clicks: Jojo
  8. Got 101 "thank you" clicks: winniethebeer
  9. Got 96 "thank you" clicks: asshunter
  10. Got 81 "thank you" clicks: vilik2003
  1. Got 9557 "thank you" clicks: ganju90
  2. Got 8080 "thank you" clicks: Bmiles90
  3. Got 7643 "thank you" clicks: kangquasar
  4. Got 5995 "thank you" clicks: blauesau
  5. Got 4861 "thank you" clicks: winniethebeer
  6. Got 4760 "thank you" clicks: qwer123
  7. Got 4071 "thank you" clicks: wm1122
  8. Got 4043 "thank you" clicks: namledn
  9. Got 3637 "thank you" clicks: tiger0008
  10. Got 3481 "thank you" clicks: Angeleye
July 2016:
The top 10 F/F posts in July 2016:
  1. Got 49 "thank you" clicks: #180032 (kayak)
  2. Got 38 "thank you" clicks: #179562 (SDS)
  3. Got 34 "thank you" clicks: #179799 (kayak)
  4. Got 32 "thank you" clicks: #181349 (anms06)
  5. Got 28 "thank you" clicks: #180525 (SDS)
  6. Got 24 "thank you" clicks: #180528 (mr.Lift)
  7. Got 21 "thank you" clicks: #181338 (wondering)
  8. Got 20 "thank you" clicks: #179882 (perun ffcarries), #179900 (ganju90), #180357 (5supermb), #180709 (ponyplay), #181281 (vtn1354)
  9. Got 19 "thank you" clicks: #180102 (anindya.akg), #180321 (tiptoeriot), #180519 (mr.Lift)
  10. Got 18 "thank you" clicks: #179912 (blauesau), #180504 (blauesau), #181202 (kayak)
  7. Got 49 "thank you" clicks: #180032 (kayak)
  8. Got 48 "thank you" clicks: #176086 (mr.Lift)
  9. Got 46 "thank you" clicks: #176519 (tiptoeriot)
  10. Got 45 "thank you" clicks: #106603 (siihxh)
The top 10 F/M posts in July 2016:
  1. Got 27 "thank you" clicks: #180332 (ugabooga_10), #180432 (spirited_667)
  2. Got 26 "thank you" clicks: #180224 (xtc)
  3. Got 24 "thank you" clicks: #180757 (gjeg0)
  4. Got 23 "thank you" clicks: #181155 (lion)
  5. Got 22 "thank you" clicks: #180355 (xbmaster73)
  6. Got 21 "thank you" clicks: #179713 (cx), #181469 (Angeleye)
  7. Got 20 "thank you" clicks: #180026 (ganju90), #180621 (ganju90), #180686 (thegoat77)
  8. Got 19 "thank you" clicks: #180086 (ganju90), #180364 (raymond), #180742 (henryspencer)
  9. Got 18 "thank you" clicks: #180018 (lion), #180342 (kangquasar), #180843 (ganju90)
  10. Got 17 "thank you" clicks: #179792 (dylan), #179870 (cx), #180281 (atlantaguy), #180391 (blinkfan4life182X), #180935 (ganju90)
The 10 highest number of thanks received by a single (non-admin) member in July 2016:
  1. Got 1550 "thank you" clicks: ganju90
  2. Got 215 "thank you" clicks: Bmiles90
  3. Got 179 "thank you" clicks: kangquasar
  4. Got 135 "thank you" clicks: mr.Lift
  5. Got 130 "thank you" clicks: cx
  6. Got 119 "thank you" clicks: Angeleye
  7. Got 117 "thank you" clicks: gotlifted
  8. Got 113 "thank you" clicks: lion
  9. Got 102 "thank you" clicks: kayak
  10. Got 90 "thank you" clicks: henryspencer
  1. Got 11107 "thank you" clicks: ganju90
  2. Got 8295 "thank you" clicks: Bmiles90
  3. Got 7822 "thank you" clicks: kangquasar
  4. Got 6061 "thank you" clicks: blauesau
  5. Got 4893 "thank you" clicks: winniethebeer
  6. Got 4782 "thank you" clicks: qwer123
  7. Got 4104 "thank you" clicks: namledn
  8. Got 4075 "thank you" clicks: wm1122
  9. Got 3719 "thank you" clicks: tiger0008
  10. Got 3600 "thank you" clicks: Angeleye
Akshayb (August 21st, 2016), (August 14th, 2016)
Old September 12th, 2016, 19:21   #127
5,519 Total
August 2016:
The top 10 F/F posts in August 2016:
  1. Got 38 "thank you" clicks: #181755 (SDS)
  2. Got 36 "thank you" clicks: #182348 (henryspencer)
  3. Got 31 "thank you" clicks: #182090 (mr.Lift)
  4. Got 28 "thank you" clicks: #182814 (mr.Lift)
  5. Got 23 "thank you" clicks: #181534 (mr.Lift), #183051 (henryspencer)
  6. Got 22 "thank you" clicks: #182342 (Leobor), #183004 (tragmich)
  7. Got 21 "thank you" clicks: #182033 (kangquasar)
  8. Got 20 "thank you" clicks: #182294 (babaloo), #183097 (henryspencer)
  9. Got 19 "thank you" clicks: #181869 (kangquasar)
  10. Got 18 "thank you" clicks: #181957 (winniethebeer), #182073 (mebalshaw), #182713 (winniethebeer), #183005 (il)
The top 10 F/M posts in August 2016:
  1. Got 54 "thank you" clicks: #182260 (tengal123)
  2. Got 38 "thank you" clicks: #181552 (FinQ)
  3. Got 27 "thank you" clicks: #181568 (xirgu20), #182851 (henryspencer)
  4. Got 24 "thank you" clicks: #182184 (utiug), #182420 (ericfabre), #182832 (Leobor)
  5. Got 23 "thank you" clicks: #181908 (qwer123), #182362 (blauesau), #183057 (guileguile)
  6. Got 22 "thank you" clicks: #181508 (dendrin), #182247 (pxig2488)
  7. Got 21 "thank you" clicks: #182301 (anindya.akg), #182536 (anms06)
  8. Got 20 "thank you" clicks: #181922 (vilik2003), #181963 (Jojo), #182206 (Jojo), #182294 (babaloo)
  9. Got 19 "thank you" clicks: #182209 (Manojutzi), #182213 (lombard), #182349 (henryspencer)
  10. Got 18 "thank you" clicks: #181686 (bravesirrobin), #182631 (GeeDee), #183052 (henryspencer)
  10. Got 54 "thank you" clicks: #182260 (tengal123)
The 10 highest number of thanks received by a single (non-admin) member in August 2016:
  1. Got 322 "thank you" clicks: kangquasar
  2. Got 216 "thank you" clicks: henryspencer
  3. Got 201 "thank you" clicks: Bmiles90
  4. Got 147 "thank you" clicks: ganju90
  5. Got 146 "thank you" clicks: mr.Lift
  6. Got 125 "thank you" clicks: Angeleye
  7. Got 114 "thank you" clicks: Leobor
  8. Got 94 "thank you" clicks: babaloo
  9. Got 89 "thank you" clicks: Jojo
  10. Got 84 "thank you" clicks: tengal123
  1. Got 11284 "thank you" clicks: ganju90
  2. Got 8501 "thank you" clicks: Bmiles90
  3. Got 8164 "thank you" clicks: kangquasar
  4. Got 6090 "thank you" clicks: blauesau
  5. Got 4947 "thank you" clicks: winniethebeer
  6. Got 4814 "thank you" clicks: qwer123
  7. Got 4170 "thank you" clicks: namledn
  8. Got 4086 "thank you" clicks: wm1122
  9. Got 3774 "thank you" clicks: tiger0008
  10. Got 3738 "thank you" clicks: Angeleye
lcarry371 (October 30th, 2024), utiug (August 1st, 2017), Rodax (September 16th, 2016), (September 13th, 2016)
Old June 23rd, 2017, 14:58   #128
Jennie01
Wink
hello guys i am new here ... that is cool to be in your web site /.. nice posts ,, ))
Jennie01 is offline
Old July 23rd, 2018, 17:07   #129
thugrex
thanks for your posts
thugrex is offline
Old June 2nd, 2019, 17:47   #130
parhamsex
Default l&C
nice page
parhamsex is offline
