Old September 6th, 2009, 09:03   #1
webppl
webppl's Avatar
973 Total
Default I am not able to access this forum
Hi, I am currently using a proxy server to access this forum. For some reason, I am being refused connection. I suspect it is because my IP address is being blocked as I have a static IP address.
Can the administrators help me in this problem?
webppl is offline
Old September 6th, 2009, 11:50   #2
shanu
shanu's Avatar
518 Total
Yes... This is the same issue with me!! I am using a proxy server as well... why has this happened suddenly? :O
shanu is offline
Old September 6th, 2009, 15:18   #3
webppl
webppl's Avatar
973 Total
Is anybody else from India having this problem?
webppl is offline
Old September 6th, 2009, 15:44   #4
5,504 Total
I will ask our web host if they've made any changes to their firewall. Last time something like this happened, it was because of a bug in the firewall rules.
dp is online now
Old September 8th, 2009, 16:09   #5
shanu
shanu's Avatar
518 Total
Well.. Now the problem is resolved!!! I am not sure if it is Indian ISP's at work... or Web hosts' firewall!! webppl, are u still having problem?
shanu is offline
Old September 8th, 2009, 20:40   #6
5,504 Total
I asked our host about this, and learned that many Indian IP addresses were temporarily firewalled for reasons that have nothing to do with you guys.
dp is online now
Old September 9th, 2009, 02:22   #7
nishnuts
41 Total
hi all
im from Bangalore
n i hv had no problems at all accessing the forum at any point in time....
by the way i hv a hathway broadband connection
nishnuts is offline
Old September 10th, 2009, 09:31   #8
webppl
webppl's Avatar
973 Total
I still cant access this forum without using a proxy
If i tell them my IP address, can they unblock it? Most BSNL broadband users get dynamic IP which changes every time. But I have a static IP since its a business plan. So I cant access the forum unless they unblock it.
webppl is offline
Old September 10th, 2009, 12:20   #9
5,504 Total
We (the admins on this forum) have no control over this, but if you want me to, I can forward your request to someone who may be able to help. I noticed that you've been using the same IP address from May 29 to Sept 3 - I assume that's the address you want to unblock?
dp is online now
Old September 11th, 2009, 06:39   #10
Same is the problem with me. I am also not able to access this site through my usual connection which I am using for last 6 months. Right now I am using some other connection.
