Old November 8th, 2016, 09:20   #1
Danielsmith12
Default Does lift and carry methord reduce the weight?
Hi friends
I am very curios about to know that does lift and carry method reduce the weight of body?I want to know about this.Does this is possible,i will try lift and carry ,method every routine.Because i love to do this.
Danielsmith12 is offline
Old November 17th, 2016, 05:07   #2
LTemplar
LTemplar's Avatar
41 Total
Originally Posted by Danielsmith12 View Post
Hi friends
It does like any other exercise. And like any other exercise, it should be done systematically, building all needed muscles. And burning fat.
LTemplar is offline
Old June 29th, 2017, 21:26   #3
Ottofuse9
1 Total
I wonder if a girl has broken her back from piggybacking
Ottofuse9 is offline
Old July 16th, 2017, 14:49   #4
modesto
1 Total
Do you mean if the body gets lighter, because it's lifted in the air? If that's your question, the answer is no. If you want to know if you can get strength by lifting a body, the answer is an empathic yes.
modesto is offline
Old July 17th, 2017, 18:04   #5
Slevin
Slevin's Avatar
619 Total
Slevin is offline
phoneman (July 19th, 2017)
Old July 19th, 2017, 22:37   #6
3,107 Total
Originally Posted by Slevin View Post
2, 11, 5, 6
Excellent answer to this question.
Slevin (October 1st, 2017)
Old July 24th, 2017, 01:48   #7
Diana Welch
Hi friends
You should include exercise that will make you sweat like running for 20 mins, because it helps reduce fats and calories
Diana Welch is offline
Old September 29th, 2017, 05:07   #8
allffcradles
1,155 Total
I assumed they were asking if the technique someone uses to carry makes the body lighter, physically no but there's a huge difference lifting someone on your back vs with your arms (Unless you got a bad back ), so the method you lift matters So it gives the impression it's lighter at least as does the liftee's state, a struggling one is more work etc hehe.
Definitely experiment! Personally I don't like giving piggybacks, for some reason I find cradling far more comfortable and easier though piggybacks should require less strength.
allffcradles is offline
Old November 16th, 2017, 14:06   #9
user666
Probably
user666 is offline
Old November 16th, 2017, 15:42   #10
3,107 Total
Originally Posted by user666 View Post
Probably
These one or two word postings are meaningless (and annoying). I think that you longest posting is five words or less. These add nothing to the conversation. Please do not think that these will help your board status.
allffcradles (November 16th, 2017)
