Old April 18th, 2021, 20:08   #1
Landcfan91
3 Total
Default How many times has a women leg pressed you in one go
So guys when a women had leg pressed you how many times has she managed to do this. I weigh 230 lbs and my wife has managed to press me 30 times with her legs. She also has just held me in the air using her legs for a total of 5 minutes when I set her the challenge. After 5 minutes was up she then proceeded to press me ten times with her legs. She finds this so easy and doesn’t do any sort of weight training at all.
Landcfan91 is offline
ilovestronggirls (May 26th, 2021), piggybackrides (May 11th, 2021)
Old April 19th, 2021, 06:36   #2
aaltra
aaltra's Avatar
439 Total
Amazon Amanda pressed me at least 10 time with one legs, ans she stoped because it was boring , not because she was tired.
She was 1m90/150kg, while I was 1m65/55 kg at that time, even not the half of her weight.
With both her legs, she could have throw me up to the ceiling !
aaltra is offline
Old April 19th, 2021, 08:37   #3
ishita
two times
ishita is offline
Old April 19th, 2021, 10:02   #4
maakran
138 Total
50 times by Tia (I weigh 150lbs)
maakran is offline
Old May 11th, 2021, 12:26   #5
Jessica1234
1 Total
Happened to me about 16 times it was cool but got use to it
Jessica1234 is offline
Old May 16th, 2021, 17:25   #6
luff(arungen)
631 Total
seeing how leg pressing at the gym is done with weights a lot bigger than what your average guy weighs, I'd say that most women would be able to leg press a man 30-50 times with ease.
Luffarungen, the one and only
luff(arungen) is offline
Old September 7th, 2025, 00:23   #7
rokko1974
3 Total
my wife can lift me (156lb) with her calves 10 times or hold me in air for 1 Minute ... her hole legs are strong as the legs of Amanda Amazon, I guess..
rokko1974 is offline
