Go Back   The Lift & Carry Forums > Welcome > LandC Lounge
Old September 7th, 2024, 06:53   #2081
Kiiroisenko
Default Please
- My password is secure - I am over 18 years old. - I found the forum while searching on Google. - I live in Turkey. - I want access
The access request needs to be posted without using your VPN. After you have been given full access, you are welcome to use your VPN. -dp
Kiiroisenko is offline   Reply With Quote
Old September 8th, 2024, 21:52   #2082
torhorn
Confirm you have chose a secure password.
I have secured my password
-Confirm you are over 18 years old.
I am in my 30s
-Tell us how you found this forum (google, another forum, facebook, etc)
I found it on girlswithmuscles
-Tell us the country you're currently living in
Canada
torhorn is offline   Reply With Quote
Old September 21st, 2024, 15:01   #2083
Gergnautan
Originally Posted by Gergnautan View Post
Im over 18
I have a secured password
I found this site through ultimate shoulder ride
Im from Germany
I’m not connected to a VPN. Can i get access?
Gergnautan is offline   Reply With Quote
Old September 23rd, 2024, 19:37   #2084
You are using Apple iCloud Private Relay, which is Apple's own VPN functionality. Here are Apple's instructions on how to turn it off:
https://www.apple.com/legal/privacy/data/en/icloud-relay/#:~:text=You%20can%20disable%20Private%20Relay,to% 20turn%20off%20Private%20Relay.
After you have been given full access, you are free to use any VPN, including iCloud Private Relay.
dp is offline   Reply With Quote
Old September 23rd, 2024, 20:01   #2085
Gergnautan
I have now turned off the VPN, can I get full access now? Thanks for the instructions
Old September 27th, 2024, 21:24   #2086
It still shows up as using Apple iCloud Private Relay.
Old September 27th, 2024, 21:32   #2087
Gergnautan
Wasn’t i suppossed to do that? So that i’m not connected to ICloud VPN? I’ve turned it off now again anyhow. Could i please receive full access now?
You need to make a post while not connected via iCloud. This post was still made via iCloud. You are free to use any VPN after you have full access. -dp
Old September 28th, 2024, 14:36   #2088
liftcoser
Request
Password secured!
I am over 18
Google searching
China
liftcoser is offline   Reply With Quote
Old September 30th, 2024, 15:24   #2089
DRMSF97
Default Standard access
Hi,
Requesting standard-level access. Below are the answers to the verification questions:
-Confirm you have chose a secure password. - Yes
-Confirm you are over 18 years old. - Yes
-Tell us how you found this forum (google, another forum, facebook, etc) - Google
-Tell us the country you're currently living in - Canada
Thanks.
DRMSF97 is offline   Reply With Quote
Old September 30th, 2024, 16:03   #2090
Gergnautan
I’ll try again, this is without using private relay, as you instructed.
I’m over 18
I found this site from ultimate shoulder ride
I’m from Germany
Hope it works this time.
No, it does not work. If you can't disable it from Safari, try another browser, for example Firefox. -dp
