Old December 1st, 2010, 14:03   #1
5,493 Total
Default Monthly top 10 lists
A few months ago, we installed a new system for giving thanks to good posts. Because of this, it is now possible to post summaries of each month's best posts and posters. I hope you find the below lists both interesting and motivating.
November 2010:
The 10 highest post ratings in November 2010:
  1. Got 17 "thank you" clicks: #45519 (Bacha), #46415 (bokostas)
  2. Got 15 "thank you" clicks: #46701 (ocatcher)
  3. Got 14 "thank you" clicks: #45650 (telbin)
  4. Got 13 "thank you" clicks: #45433 (pqowieus2000), #45642 (SDS), #45903 (SDS)
  5. Got 12 "thank you" clicks: #45601 (tragmich)
  6. Got 11 "thank you" clicks: #45506 (yakuza), #45595 (hejikiz), #45862 (vtn1354), #46031 (SDS), #46327 (lenny)
  7. Got 10 "thank you" clicks: #45434 (pqowieus2000), #45594 (tragmich), #46329 (lenny), #46623 (100proof)
  8. Got 9 "thank you" clicks: #45215 (arav1605), #45337 (phoneman), #45510 (mitchell1782), #45883 (jackjeep2000), #45949 (bsn0327)
  9. Got 8 "thank you" clicks: #45214 (arav1605), #45216 (arav1605), #45238 (wm1122), #45355 (mishamironovv), #45853 (tragmich), #46162 (cobb308), #46405 (SDS), #46433 (bsn0327), #46569 (dendrin), #46619 (raymond)
  10. Got 7 "thank you" clicks: #44993 (wm1122), #44995 (wm1122), #45055 (Vodevil), #45194 (phoneman), #45429 (pqowieus2000), #45474 (mitchell1782), #45615 (dendrin), #45706 (mitchell1782), #45931 (templebevelle), #46189 (perun ffcarries), #46521 (DWayne), #46590 (arav1605), #46591 (arav1605), #46592 (arav1605)
The 10 highest post ratings since the post ratings started:
  1. Got 34 "thank you" clicks: #43994 (filmguy)
  2. Got 17 "thank you" clicks: #45519 (Bacha), #46415 (bokostas)
  3. Got 15 "thank you" clicks: #46701 (ocatcher)
  4. Got 14 "thank you" clicks: #43063 (ocatcher), #44018 (tragmich), #45650 (telbin)
  5. Got 13 "thank you" clicks: #43214 (ocatcher), #45433 (pqowieus2000), #45642 (SDS), #45903 (SDS)
  6. Got 12 "thank you" clicks: #42414 (tragmich), #44214 (ocatcher), #45601 (tragmich)
  7. Got 11 "thank you" clicks: #43060 (ocatcher), #43379 (jj009), #43764 (vvoloc), #43792 (guy6546546), #44128 (lenny), #44349 (nishnuts), #45506 (yakuza), #45595 (hejikiz), #45862 (vtn1354), #46031 (SDS), #46327 (lenny)
  8. Got 10 "thank you" clicks: #43061 (ocatcher), #43965 (thegreatrodge), #44050 (wm1122), #44832 (dendrin), #45434 (pqowieus2000), #45594 (tragmich), #46329 (lenny), #46623 (100proof)
  9. Got 9 "thank you" clicks: #42433 (dendrin), #42440 (Bold), #42646 (mishamironovv), #43212 (ocatcher), #44382 (SDS), #44651 (tragmich), #45215 (arav1605), #45337 (phoneman), #45510 (mitchell1782), #45883 (jackjeep2000), #45949 (bsn0327)
  10. Got 8 "thank you" clicks: #42891 (Wordgazer2), #43145 (dendrin), #43317 (trebuchets), #43390 (jj009), #44052 (wm1122), #44535 (thegreatrodge), #44598 (kinera), #44822 (Coolbeans), #44957 (tragmich), #44959 (tragmich), #45214 (arav1605), #45216 (arav1605), #45238 (wm1122), #45355 (mishamironovv), #45853 (tragmich), #46162 (cobb308), #46405 (SDS), #46433 (bsn0327), #46569 (dendrin), #46619 (raymond)
The 10 highest number of thanks received by a single (non-admin) member in November 2010:
  1. Got 104 "thank you" clicks: pqowieus2000
  2. Got 68 "thank you" clicks: arav1605
  3. Got 65 "thank you" clicks: SDS
  4. Got 55 "thank you" clicks: wm1122
  5. Got 36 "thank you" clicks: Bacha, mitchell1782
  6. Got 34 "thank you" clicks: lenny
  7. Got 30 "thank you" clicks: Mike
  8. Got 25 "thank you" clicks: kiranhs2310
  9. Got 22 "thank you" clicks: bsn0327
  10. Got 20 "thank you" clicks: bokostas
The 10 highest number of thanks received by a single (non-admin) member since the post ratings started:
  1. Got 132 "thank you" clicks: ocatcher
  2. Got 120 "thank you" clicks: wm1122
  3. Got 112 "thank you" clicks: pqowieus2000
  4. Got 78 "thank you" clicks: SDS
  5. Got 70 "thank you" clicks: arav1605
  6. Got 54 "thank you" clicks: lenny
  7. Got 38 "thank you" clicks: Mike
  8. Got 36 "thank you" clicks: Bacha, blauesau, mitchell1782
  9. Got 35 "thank you" clicks: filmguy
  10. Got 29 "thank you" clicks: thegreatrodge, Wordgazer2
(December 10th, 2010)
Old December 12th, 2010, 04:41   #2
wm1122
5,050 Total
Thats a very fun stat to look at. Is it possible without doing more work, to break the list down ever farther and give the totals, then give the totals for most thanks for F/F and F/M separetly.
November 2010:
wm1122 is offline
Old December 13th, 2010, 14:21   #3
5,493 Total
You mean the "top 10 posts" lists, right? It is possible to do that, but maybe you prefer "top 5" instead of "top 10" in that case? There will be less high-rated posts when we separate the F/M and F/F posts into two lists, so we might want to go from 10 to 5.
I appreciate feedback on this, so I hope you or anyone with strong opinions about it will let me know what they think.
Old December 14th, 2010, 04:12   #4
wm1122
5,050 Total
Good point, top 5 for each would be good.
wm1122 is offline
Old December 14th, 2010, 21:47   #5
5,493 Total
Here's November's summaries again, now with F/F and F/M separated into two top 5 lists. If you prefer the previous presentation format, let me know, or I will use this from now on.
November 2010:
The 5 highest F/F post ratings in November 2010:
  1. Got 14 "thank you" clicks: #45642 (SDS)
  2. Got 13 "thank you" clicks: #45903 (SDS)
  3. Got 12 "thank you" clicks: #45595 (hejikiz)
  4. Got 11 "thank you" clicks: #45506 (yakuza), #45862 (vtn1354), #46031 (SDS), #46623 (100proof)
  5. Got 10 "thank you" clicks: #45355 (mishamironovv), #45594 (tragmich)
The 5 highest F/F post ratings since the post ratings started:
  4. Got 11 "thank you" clicks: #43379 (jj009), #43792 (guy6546546), #45506 (yakuza), #45862 (vtn1354), #46031 (SDS), #46623 (100proof)
  5. Got 10 "thank you" clicks: #44050 (wm1122), #44832 (dendrin), #45355 (mishamironovv), #45594 (tragmich)
The 5 highest F/M post ratings in November 2010:
  1. Got 25 "thank you" clicks: #46701 (ocatcher)
  2. Got 19 "thank you" clicks: #46415 (bokostas)
  3. Got 17 "thank you" clicks: #45519 (Bacha)
  4. Got 14 "thank you" clicks: #45650 (telbin), #46888 (Bacha)
  5. Got 13 "thank you" clicks: #45433 (pqowieus2000), #45601 (tragmich)
The 5 highest F/M post ratings since the post ratings started:
  2. Got 25 "thank you" clicks: #46701 (ocatcher)
  3. Got 19 "thank you" clicks: #46415 (bokostas)
  4. Got 17 "thank you" clicks: #45519 (Bacha)
  5. Got 14 "thank you" clicks: #43063 (ocatcher), #44018 (tragmich), #45650 (telbin), #46888 (Bacha)
  2. Got 76 "thank you" clicks: arav1605
  3. Got 67 "thank you" clicks: SDS
  4. Got 62 "thank you" clicks: Bacha
  5. Got 55 "thank you" clicks: wm1122
  6. Got 38 "thank you" clicks: Mike
  7. Got 36 "thank you" clicks: lenny, mitchell1782
  8. Got 29 "thank you" clicks: ocatcher
  9. Got 25 "thank you" clicks: kiranhs2310
  10. Got 24 "thank you" clicks: bsn0327
  1. Got 144 "thank you" clicks: ocatcher
  4. Got 80 "thank you" clicks: SDS
  5. Got 78 "thank you" clicks: arav1605
  6. Got 62 "thank you" clicks: Bacha
  7. Got 56 "thank you" clicks: lenny
  8. Got 46 "thank you" clicks: Mike
  9. Got 38 "thank you" clicks: blauesau
  10. Got 36 "thank you" clicks: mitchell1782, thegreatrodge
Old December 15th, 2010, 03:16   #6
This one looks better.
November 2010:
Old December 19th, 2010, 09:02   #7
rwlm
King of Intergender Wrestling
rwlm's Avatar
1,168 Total
Default monthly top 10 list
quote from dp: i hope u find below the top 10 list, interesting and motivation.REPLY - its interesting, but as far as motivation goes, well no to this. in most cases the members whom make the top 10 list are members whom post lots of pictures in one post and quite rightly member click the thank u button in appreciation of the time and effort in posting these wonderful pictures. BUT for clip finders its a totally different story, especilly for members whom post mainly youtube clips. although we may only post clip at a time, a lot of time is spent watching clips for lifts, looking for a needle in a haystack sometimes - figure of speech trying to find clips with very low views, so that it will be new or hopefully new for members to watch. but when it comes to clicking the thank u button, well what can i say EXCEPT to say, u will never see my name in the top 10, no matter how good the clip is. ANYWAY as xms is fast approaching, i like to take this opportunity to wish all members of this forum a merry xmas and a happy new, and drive carefully on the roads during this period.
rwlm is offline
Old December 19th, 2010, 09:47   #8
5,493 Total
Originally Posted by rwlm View Post
... BUT for clip finders its a totally different story, especilly for members whom post mainly youtube clips. although we may only post clip at a time, a lot of time is spent watching clips for lifts, looking for a needle in a haystack sometimes - figure of speech trying to find clips with very low views, so that it will be new or hopefully new for members to watch. but when it comes to clicking the thank u button, well what can i say EXCEPT to say, u will never see my name in the top 10, no matter how good the clip is.
Don't be so sure, the highest rated post got 34 clicks, and it was a single video clip. It will probably be hard to get this with a wrestling clip, though. (Unless a WWE diva like Kelly Kelly or Kaitlyn gorilla presses a male wrestler or something... )
You too Ray, although you probably don't need to. The roads don't get very icy this time of year in your hemisphere, do they?
Old December 21st, 2010, 15:07   #9
3,104 Total
Ray, I tend to agree with you about the needle in the haystack issues of finding clips. While some clips may get 20 or 30 thanks, it really is very time consuming to keep finding clips that may be new. It is a real pain in the butt to watch a 5 minute clip, looking for that one 10 or 15 or 30 second part and then learing that there is no lift in the clip at all - or if there is a lift, it is 2 seconds long and not worth posting. Your contributions are great and are obviously the result of tremendous efforts on your part, whether you get lots of thank you posts or not.
rwlm (January 4th, 2011)
Old January 2nd, 2011, 11:45   #10
5,493 Total
December 2010:
The 5 highest F/F post ratings in December 2010:
  1. Got 25 "thank you" clicks: #47695 (ganju90)
  2. Got 15 "thank you" clicks: #47382 (kangquasar), #47520 (ganju90)
  3. Got 14 "thank you" clicks: #48036 (mishamironovv)
  4. Got 12 "thank you" clicks: #47616 (wm1122), #47989 (yakuza)
  5. Got 11 "thank you" clicks: #47606 (blauesau), #47845 (kangquasar)
  2. Got 15 "thank you" clicks: #45642 (SDS), #47382 (kangquasar), #47520 (ganju90)
  4. Got 13 "thank you" clicks: #45903 (SDS)
  5. Got 12 "thank you" clicks: #45595 (hejikiz), #47616 (wm1122), #47989 (yakuza)
The 5 highest F/M post ratings in December 2010:
  1. Got 59 "thank you" clicks: #47984 (ocatcher)
  2. Got 43 "thank you" clicks: #47697 (ganju90)
  3. Got 26 "thank you" clicks: #47525 (ganju90)
  4. Got 25 "thank you" clicks: #47754 (ganju90)
  5. Got 20 "thank you" clicks: #47545 (ganju90)
  3. Got 34 "thank you" clicks: #43994 (filmguy)
  4. Got 28 "thank you" clicks: #46701 (ocatcher)
  5. Got 26 "thank you" clicks: #47525 (ganju90)
The 10 highest number of thanks received by a single (non-admin) member in December 2010:
  1. Got 208 "thank you" clicks: kangquasar
  2. Got 168 "thank you" clicks: ganju90
  3. Got 67 "thank you" clicks: ocatcher
  4. Got 58 "thank you" clicks: wm1122
  5. Got 49 "thank you" clicks: Bacha
  6. Got 42 "thank you" clicks: lenny
  7. Got 34 "thank you" clicks: blauesau
  8. Got 27 "thank you" clicks: ricardo0606
  9. Got 25 "thank you" clicks: rwlm
  10. Got 24 "thank you" clicks: memosan11
  1. Got 216 "thank you" clicks: ocatcher
  2. Got 208 "thank you" clicks: kangquasar
  3. Got 178 "thank you" clicks: wm1122
  4. Got 173 "thank you" clicks: ganju90
  5. Got 112 "thank you" clicks: Bacha, pqowieus2000
  6. Got 99 "thank you" clicks: lenny
  7. Got 91 "thank you" clicks: SDS
  8. Got 79 "thank you" clicks: arav1605
  9. Got 73 "thank you" clicks: blauesau
  10. Got 67 "thank you" clicks: lionman
