Old September 6th, 2009, 09:03   #1
webppl
webppl's Avatar
962 Total
Default I am not able to access this forum
Hi, I am currently using a proxy server to access this forum. For some reason, I am being refused connection. I suspect it is because my IP address is being blocked as I have a static IP address.
Can the administrators help me in this problem?
webppl is offline
Old September 6th, 2009, 11:50   #2
shanu
shanu's Avatar
518 Total
Yes... This is the same issue with me!! I am using a proxy server as well... why has this happened suddenly? :O
shanu is offline
Old September 6th, 2009, 15:18   #3
webppl
webppl's Avatar
962 Total
Is anybody else from India having this problem?
webppl is offline
Old September 6th, 2009, 15:44   #4
I will ask our web host if they've made any changes to their firewall. Last time something like this happened, it was because of a bug in the firewall rules.
Old September 8th, 2009, 16:09   #5
shanu
shanu's Avatar
518 Total
Well.. Now the problem is resolved!!! I am not sure if it is Indian ISP's at work... or Web hosts' firewall!! webppl, are u still having problem?
shanu is offline
Old September 8th, 2009, 20:40   #6
I asked our host about this, and learned that many Indian IP addresses were temporarily firewalled for reasons that have nothing to do with you guys.
Old September 9th, 2009, 02:22   #7
nishnuts
40 Total
hi all
im from Bangalore
n i hv had no problems at all accessing the forum at any point in time....
by the way i hv a hathway broadband connection
nishnuts is offline
Old September 10th, 2009, 09:31   #8
webppl
webppl's Avatar
962 Total
I still cant access this forum without using a proxy
If i tell them my IP address, can they unblock it? Most BSNL broadband users get dynamic IP which changes every time. But I have a static IP since its a business plan. So I cant access the forum unless they unblock it.
webppl is offline
Old September 10th, 2009, 12:20   #9
We (the admins on this forum) have no control over this, but if you want me to, I can forward your request to someone who may be able to help. I noticed that you've been using the same IP address from May 29 to Sept 3 - I assume that's the address you want to unblock?
Old September 11th, 2009, 06:39   #10
goneju
Guest
Posts: n/a
Same is the problem with me. I am also not able to access this site through my usual connection which I am using for last 6 months. Right now I am using some other connection.
