Old March 26th, 2009, 17:33   #1
5,529 Total
Default Having problems connecting to this forum?
We have received reports that some people recently (since Saturday, March 21st) started having problems connecting to the forum from certain Internet providers.
The most likely reason for this problem is that our forum was moved to a new (faster) web server on March 21st, and your name servers have not yet refreshed their records. (Name servers are what translates a human readable address like LANDCFORUM.COM into a numeric address that the computers understand. If the name servers fail, you can't connect.)
If I'm right, your problem will fix itself eventually, but if it doesn't, those of you that still have to jump through some hoops to be able to connect should tell me about it here.
Old March 30th, 2009, 14:07   #2
ugabooga_10
329 Total
yeah i have this problem
i have to go through hidemyass.com to get here
but it slows down the site when i use it
its very annoying
ugabooga_10 is offline
Old March 30th, 2009, 19:02   #3
5,529 Total
its very annoying
We are investigating this issue as we speak. The DNS theory I mentioned above seems to be false. You can verify this yourself by starting the command prompt (cmd) and typing tracert landcforum.com. If it lists a bunch of addresses, but stops after outputting several lines of "Request timed out", then you have the same problem as the other users that can't connect.
We don't yet know why our server rejects some of you, but we can tell you that we didn't mean for that to happen. No-one has intentionally been banned at that level.
I will post updates to this problem in this thread, so please check it out from time to time.
Old March 31st, 2009, 06:21   #4
nishadh
604 Total
Hi dp,
I am now able to get in. Here is what happened- I bought the latest daisy clip from vidown.com. But i was not able to download it as it was hosted on amazonbitches.com. I figured it was the same problem as here and i found out that if i tracert both these sites i was getting stuck at that same point. So i sent that same tracert window to their tech support and he gave me this reply - "Try it again. Your IP address is in a previously unused range and was being blocked by a firewall rule."
So i guess it is the same problem for everyone. Now i m able to get in, but others might need to get their ips registered with them.
nishadh is offline
Old March 31st, 2009, 08:54   #5
5,529 Total
Originally Posted by nishadh View Post
Hi dp,
Thanks again nishadh! Every member with STANDARD membership or better has now been notified over email.
Old March 31st, 2009, 21:05   #6
smallwm
44 Total
Now I am able to access this great site. Lots up catching up tp do lol!
smallwm is offline
Old April 1st, 2009, 11:20   #7
nishadh
604 Total
nishadh is offline
Old April 1st, 2009, 13:18   #8
ugabooga_10
329 Total
Talking
im not sure what uve done but everything seems to be working well now
thank you
see u in the forum
Old April 3rd, 2009, 11:02   #9
kly_lin
1,961 Total
yes, I have to use a proxy to browse this website, but it's not so fortunate when openning some free archive sharing websites like megaupload.com, I am blocked away from it.
kly_lin is offline
Old April 3rd, 2009, 13:44   #10
5,529 Total
You mean you had to use a proxy, right? You don't need one now?
